Old 10-16-2020, 03:09 PM   #1
Septic Smell Inside of Coach
I'm having a septic smell in the coach of my Forester 3011DS. I've researched this and read all of the responses. My problem appears different from the others.
We have emptied both tanks; flushed the black tank fir a LONG time; added deodorizer; even put dodeizer down the drains and shower. I've done this the same way for four years with no oroblems. My toilet is a porcelain Dometic 310; plenty of water in the bowl (which doesn't leak out.). I also checked the vent stack but the cover on the roof is not removable. There's no smell coming from there but I cannot tell of it's plugged.
Despite doing everything that we've always done, I cannot get rid of the septic smell. We just returned from a 9-week trip and it started on the last day on the way home.
Any ideas?
Mach428 is offline   Reply With Quote
Old 10-16-2020, 03:42 PM   #2
Ambassador Member
Duckogram's Avatar
Septic smell aka rotten eggs is sometimes due to the vent under the sink not working. It unscrews by hand so you can check it. Lots of posts on the subject.
Ducky
‘18 Sunseeker 2800QS
Towing Smart
No PM’s.
Old 10-16-2020, 04:38 PM   #3
Iggy's Avatar
Just my suggestion is to fill with fresh water prior to a trip and let it slush around while you drive. Even add a good dose of deodorizer.
When you get to your 1st campground stop dump and re fill before leaving for your next stop.
How do you flush?
Now just for clarity even if you flush and leave valve open and the water looks clear doesn't mean all the solids are out.
It needs lots of water in the tank to clean anything on the walls and even bottom.
So as I said you really have to fill and flush numerous times to get that stuff and smell out.
2012 Georgetown XL 378TS
Facebook Georgetown Owners Club
Old 10-16-2020, 05:02 PM   #4
How do you flush?
Fill with some fresh water, maybe 30% full, and add two 20lb bags of ice. The ice will slosh around and mechanically clean the tank.
knot is offline   Reply With Quote
Old 10-16-2020, 05:07 PM   #5
But how are the fumes getting inside the coach??
Old 10-16-2020, 05:13 PM   #6
Ambassador Member
Duckogram's Avatar
I guess you checked the vent and its OK.
Next possibility is the flush nozzle fitting. It has three screws that hold it to the tank. If one or more are stripped in the plastic then you could get seepage into the compartment. That will stink up the coach as well.
Ducky
Towing Smart
No PM’s.
Old 10-16-2020, 05:19 PM   #7
Mechanical Plumbing Vent , AKA Air admittance valve. Located under 1 of your sinks has failed. Any hardware store will have. No tools needed to replace. 6 - 8 dollars. Buy 2 for a spare. Check it out.
Mike Tav is offline   Reply With Quote
Old 10-16-2020, 05:31 PM   #8
2012 Solera
My porcelain Dometic 310 failed in the same manner as noted in the various plastic Dometic 300 posts. Leaked sewage into a cavity in the (plastic) toilet base. I believe the design of the 300 series toilets (300, 310 and 320) is essentially identical. Don’t know why the 310 and 320 toilets seem to last longer before they fail. My original 310 lasted ~7 years before that failure occurred.
FYI, Jim
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-17-2020, 03:50 AM   #9
Thanks so much for the information folks. Greatly appreciated.
Old 10-17-2020, 11:46 AM   #10
Okay, I always like to post the cure. I did replace both vacuum breakers on the plumbing but just happened to notice that one of the burners on the stove was on low. That was the smell!!! It's all cleared up now but I wanted to thank you all for taking the time to respond.
Old 10-17-2020, 12:18 PM   #11
Don't buy cheap chemical... I have been using Aqua Chem for years... no odor...SEE:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 (check the ratings !!)
Use about 6 oz for your tank..
Clint...
2015 F350 4x4 gasser.. 2017 Rockwood 2506S TT
Ardenvoir, Washington (near Wenatchee)
clintbonnie73 is offline   Reply With Quote
Old 10-17-2020, 03:32 PM   #12
Ambassador Member
Duckogram's Avatar
Thanks for posting the solution. Im surprised that propane smelled like septic.
Ducky
Towing Smart
No PM’s.
Old 10-17-2020, 03:55 PM   #13
Mercaptan!
Mercaptan, the odor chemical included in natural gas, doesn't smell septic to me, either.
There are a couple of threads about special knobs for your RV range that can't be turned by accident. They have to be pushed and turned at the same time or somesuch.
Larry
Larry-NC is offline   Reply With Quote
Old 10-17-2020, 09:46 PM   #14
Thank God nothing but smell happened! Glad you found the problem...
SLU2 is offline   Reply With Quote
Old 10-18-2020, 09:38 AM   #15
Um, your TT is supposed to have a detector to alert you to propane gas and carbon monoxide. I think you should get that thing checked, just saying.
campers302 is offline   Reply With Quote
Old 10-18-2020, 01:52 PM   #16
Usually Confused Member
emm-dee's Avatar
Quit using that stuff unless you have access to a hazardous waste dump site. It eliminates smell with formaldehyde. Not good.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 10-18-2020, 03:03 PM   #17
Formaldehyde?
Formaldehyde? They would permanently ban you from our campground if they caught you using that stuff. They have already had issues of people dumping chemicals that messed up the biome in the septic system. That's when the policy was pubicized.
Larry
Old 10-18-2020, 03:06 PM   #18
emm-dee's Avatar
Yep....formaldehyde.
Old 10-18-2020, 04:08 PM   #19
Um, he does not have a TT.
OMG, really.
TT coach RV popup aframe whatever same same.
Old 10-18-2020, 05:06 PM   #20
Really Really! You said “Have Fun”. So I did.
