Old 07-12-2020, 06:10 PM   #1
Question Shower doesn't drain
Hi, I am new to RVing and this forum. I have a 2005 Sunseeker 2200, which I just started traveling in and figuring out all the ins and outs.
This morning, my shower did not drain, even after several hours. I did hear gurgling at the end of the shower. The light panel indicates the gray tank is empty. Help! And thank you.
Duboser is offline   Reply With Quote
Old 07-12-2020, 06:33 PM   #2
A32Deuce's Avatar
Try draining the gray tank and see if it goes down. When the shower does not drain, that's how I know the tank is full.
A32Deuce is offline   Reply With Quote
Old 07-13-2020, 12:14 PM   #3
you can't always rely on the tank monitors. If it isn't draining then try draining the grey tank.
lacrawgator is offline   Reply With Quote
Old 07-13-2020, 12:19 PM   #4
Oaklevel's Avatar
If you showered the gray tank can not be empty. My guess is your tank is full. As others have mentioned the indicator lights are rarely correct.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-13-2020, 02:45 PM   #5
Motorized GM
The other possibility is if it has a Hepvo valve. Sometimes people still pour antifreeze down that trap and that can become sticky on the Hepvo valve...so the rubber flap does not open all the way.
Please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx Don't forget to subscribe to our YouTube page for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Old 07-13-2020, 05:05 PM   #6
dbledan's Avatar
So how do you unstick that? Or do you just have to replace it then?
dbledan is offline   Reply With Quote
Old 07-13-2020, 07:28 PM   #7
Motorized GM
First I would verify that the gray tank vent is not clogged (IE no mud wasps or other varmit building a nest).
Second, I would make sure the gray tank (regardless of reading) is not full
Then, if you watch a video on how a Hepvo valve works, and understand it, I would try to force a decent amount of water into it. I have used a water bottle to unclog a toilet (clean water, but no plunger)...fill it with water, then squeeze it quickly into the toilet to force water. A hose would work too....but now you're dealing with an unlimited supply of water and that has its own potential issues.
A plunger would work too...but again, I would be concerned not with the push (but the pull). There are few different ways to skin this cat.
Old 07-13-2020, 07:37 PM   #8
Wink shower doesn't drain
One cup baking soda into drain and 2-3 cups vinegar. Leave overnight, then use some boiling water from kettle to flush. Our drain plugged and this cleared it up. Now we do this as a preventative measure about every 6 weeks
Kaptain is offline   Reply With Quote
Old 07-13-2020, 07:47 PM   #9
Just as confused as you
Scrapper's Avatar
Some of the Hepvo valves come apart for cleaning.
Richard & Jill
Camping since 1989
Everyone gets confused at some time, some are better at hiding it than others.
Old 07-13-2020, 08:53 PM   #10
Problem solved!
Thank you all for your suggestions. I tried the baking soda and vinegar first with no success. So, I drained the gray water tank and problem solved. Really appreciate your help!
Old 07-13-2020, 10:09 PM   #11
Motorized GM
Good to hear.
I think sometimes we look for complex solutions to simple problems.
Old 07-13-2020, 10:20 PM   #12
Usually Confused Member
emm-dee's Avatar
Pretty sure the first indication of a full gray tank is when the shower starts to back up. It’s usually the lowest point in the system.
2018 Forester 3051S (aka Clyde, the rolling roadblock)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 07-13-2020, 11:43 PM   #13
bikendan's Avatar
Now you know not to trust the tank idiot lights.
drain, show, shower
