Originally Posted by Sagecoachdriver
I never touched that calibration only the did the one shown in youtube video to set stops by extending and drawing slide in a foot then back out a number of times. I have good sealing and it doesn't push out the fascia. This is not the calibration you are talking about, right? Anyway, it ain't broke so no need to fix it!
No, it is a different calibration. The procedure you did synchronizes the motors.
That is important. The “stops” are a product of resistance causing an electrical event which is known as the Hall Effect. Technically you cannot physically set stops on a Schwintek in wall slideout.
The important piece is that after you sync your motors, your slide(s) work perfectly. Lucky you.
