Old 12-06-2015, 08:44 PM   #21
Originally Posted by Kevin & Judy View Post
Which video?
I found a few of them, One said to use a lithium type lube.
https://youtu.be/8KbVRFMo1Rg
2014 SunSeeker 3170DS
Ford F-450
drakethib is offline   Reply With Quote
Old 12-06-2015, 08:53 PM   #22
Boso's Avatar
The CRC power lube is what's recompense that's what I use don't use anything that attracts dirt& dust and as I said before don't worry about rust it's aluminum
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 12-07-2015, 12:08 PM   #23
There's two rollers under the slide as well - perhaps they are the source of the noise.
The directions also have you lube the gib blocks and shafts in where the gears mate with the gear rack. An innernet search will help with all the lube points on the Schwintek slides.
2016 Sunseeker 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is online now   Reply With Quote
slide, slide out
