Old 10-04-2017, 01:43 PM   #1
Slide topper wear
I was on the roof of our 2017 Forester 3051 today. I noticed that there is a hole starting in the center of the slide topper due to rolling over a screw head when pulling in or opening the slide. Has this happened to anyone else? We have had the 3051 for approximately 16 months so no longer under warranty. Any suggestions? Thanks
13STL
2017 Forester 3051S
Jill, Mark (and dogs Paco & Isabel)
13STL is offline   Reply With Quote
Old 10-04-2017, 01:48 PM   #2
Kasual Kamper
Stuff happens. Put a patch over it before the hole gets any bigger.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 10-04-2017, 01:53 PM   #3
Yes, I realize stuff happens. I was wondering what others used to patch the topper.
13STL
2017 Forester 3051S
Old 10-04-2017, 02:17 PM   #4
Kasual Kamper
I've used this. It works really well and held for 2 years on my old camper.
https://www.amazon.com/Incom-Manufac...dp/B001Y8NEX2/
Old 10-04-2017, 02:21 PM   #5
Take photos and contact the appropriate person at Forester.
At 16 months they may still help you out.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=88
Old 10-04-2017, 02:22 PM   #6
Thanks so much. I just ordered it.
13STL
2017 Forester 3051S
Old 10-04-2017, 02:23 PM   #7
Okay, I will. Thanks.
13STL
2017 Forester 3051S
Old 10-04-2017, 09:57 PM   #8
Yes, it happened to our 2016 3051 at 11 months. Forest River covered replacing the awning fabric under warranty at that time. Then exactly the same awning damage was noted at 22 months. Since it was a recurring issue obviously caused by hardware, FR replaced the fabric and the Slide topper hardware. The roller assembly that supports the center of the awning was the problem.
dyeats is offline   Reply With Quote
Old 10-05-2017, 05:51 AM   #9
Thanks for your response. That is exactly what it seems.
13STL
2017 Forester 3051S
slide
