Old 09-07-2024, 07:26 PM   #1
Red face Slideout
My Forester has three slideouts but one is not functioning. Does each one have its own dedicated fuse? I’m a new owner and am on a learning curve so thanks!
Babybehemoth is offline   Reply With Quote
Old 09-07-2024, 08:03 PM   #2
bikendan's Avatar
It always helps if you provided the year, make and model number of your Forester.
Old 09-30-2024, 12:40 PM   #3
Slide Out Fuse?
I have a similar question as the OP, I have a 2004 Sunseeker 2860DS. The issue I am having is my bedroom slide out does not seem to have any power to it, in/out button does nothing, I can't hear the motor engage at all. The slide-out still goes in and out using the manual option but that is not ideal. Are the slide-outs on separate fuses (my living room slide still works fine), if so where are these fuses located? I know where the fuse box is at the base of the bed but nothing in there is labeled or if it was you can't read it anymore.
Thank you for your time.
eddyed801 is offline   Reply With Quote
Old 09-30-2024, 02:28 PM   #4
Not sure when Forest River started using the Battery Control Center, but on my 2017 2861 the control center is on the left side of the stair well and the slide fuses are in there. If you have no control center, then look in the battery compartment for re-settable fuses for the slides.
2017 Forester 2861DS
towing 2015 Jeep Rubicon
fobagbob is offline   Reply With Quote
slide, slideout
