Slideout Structure
I have a"New" 2004 Sunseeker 2890 DS. I want to add accessory baskets over the bed in the slide. I am considering installing the baskets on a wood trim board that would be attached along the outside wall of the slide and between the side walls and the vertical curtain track, which is screwed to the wall panel or something inside it. I want to be able to put glasses, iPads and spare batteries, medications, etc in the basket so it will have a little weight. Does anyone know if there is structure in the corner of the slide or under the vertical curtain rail that I can attach to?
Thank you.
