Old 12-24-2018, 10:13 PM   #1
Rjpetr65's Avatar
Soft spot in floor
I have an 04 Sunseeker that has a soft spot about the size of a grapefruit near the bathroom in the living area. No leaks that I can see from anywhere. Perhaps the previous owner had some sort of leak.
Any suggestions for an easy and long term fix? Although I suppose that “easy and long term” is sort of an oxymoron like jumbo shrimp!
I really don’t want to start cutting out pierces of flooring if it’s not necessary.
Rich
2018 fR3 30ds. Victron multiplus 2 2x120 24 volt lifepo4
Rjpetr65 is offline   Reply With Quote
Old 12-24-2018, 10:22 PM   #2
Surveyor Mike's Avatar
If there's no apparent leak I guess it's coming from the bottom. You could probably put some Automotive grade flat sheet metal spanning the hole for rigidity underneath the linoleum or carpet glued to the subfloor. Same on the bottom side once you remove the black tar paper like barrier to see better. Good luck
2004 Surveyor 291 ultralite
2008 Ram 1500 quadcab Hemi
Surveyor Mike is offline   Reply With Quote
floor
