Beware winterizing with compressed air only.
That method may not get all of the water out of the system -- especially the toilet valve.
My procedure:
I open the low point drain and let all the water drain out.
Close low point drain.
Drain fresh water holding tank.
Remove the water filter and empty water from canister. Reinstall canister.
Blow out lines with compressed air.
Bypass and drain water heater.
Use a small hose to siphon remaining water out of water heater.
Blow out lines again.
Open low point drains again then close.
Remove the hose going to the inlet side of the water pump and leave it off until spring.
(You don't want water that may be left in the bottom of the holding tank to make it's way to the pump.)
I purchased 2 plastic fittings and piece of clear hose at the hardware store for less than $10.
Put the 90 deg. fitting on the water pump inlet.
Thread the other fitting with a hose adapter to the 90 deg fitting.
Attach the hose to the fitting and insert the other end into the antifreeze jug.
(Didn't have to remove the cover, or drill holes - the pump is on rubber mounts and moves enough to get the fitting on without any of that.)
Pump about 4 gallons of antifreeze through the system. (I know a little overkill but it's cheap.) Don't forget the outside shower that never gets used.
Remove fittings from water pump inlet.
Remove water filter canister and dump anti-freeze back in jug.
Clean canister and store in a safe place until spring.
Empty black water holding tank.
Go to fridge and enjoy an adult beverage of choice while you think about the great camping season you just had with your Sunseeker MH and how much you can't wait for spring.
