Originally Posted by Kchamp40
Thanks but I feel challenged. The only way I could figure out to get TV speakers off was to lower the volume all the way. Jensen is on HDMI arc. This is my sound menu for the TV do you see anything I should change? Much appreciated! FYI I learned in this feed is the sea speaker is for the sub woofer that is apparently under the table.
Attachment 149845
Turning off the speakers will not help you get audio from the TV(which I take it you are watching broadcast TV) to the Jensen. The only way to get audio for the broadcast TV is connect a cable from the Line Out or Headphone jack out on the TV and connect to the Jensen receiver AUX Line input.
Using the Headphone jack you would need to turn up the volume on the TV to send an audio signal to the Receiver.
Now if the TV has a Line out, 99.999% of the time that is NOT controlled by the volume control.
Now in your Pic... is says SPIDF... that is digital signal which could be a RCA type jack or Fiber Optic, THO the Jansen receiver would have to have a SPIDF input(which I doubt).
Now getting the audio cable might be a challenge... like my Sandpiper, the cables go thru the walls to the area where the Jensen Receiver is at, luckily I can remove a panel below it an access all the Jensen ins and outs!!! But if I had to run new cables it might be a challenge.
Now my Sandpiper did have the audio cables going from the TV to the AUX in on the Jensen, where the Sandpiper is at we do not get broadcast, so we use DirecTV and I connected the audio cable to it so we can hear the Sat box thu all of the speakers, A: Living Room B: Bedroom C: Outside!
I think my Jensen has a Audio in on the front of the receiver, that is to connect old school cassette player or a iPod from the headphone jack to it!
Check and see if you can do any of these. If not then a Sound Bar looks like it will be in your future!
By the way the HDMI arc is for the HDMI cable that goes from your Jensen DVD unit to the TV, so it displays the highest quality picture that a standard DVD can offer!!
