Old 04-06-2015, 01:46 PM   #1
Steering go Stabilizer advice
We have a 3050s Sunseeker Motorhome that we bought new last spring.We are really enjoying it except for the times when we encounter strong winds.
We have read some of the posts from awhile back.We would like some advice as to where to purchase and who do you get to install and recalibrate as needed.We live in Ontario Canada and no Camping World near by.For,people who have gone ahead with this- has it made enough of a difference to make it worthwhile?
Does Forest River have any advice on this( Brian.)
Thanks so much!We love our unit!
sunseekercamper56 is offline   Reply With Quote
Old 04-06-2015, 07:44 PM   #2
I have had the roadmaster reflex steering stabilizer on 2 class c mh and imo it has helped greatly along with the front end alignment set to the specs found in this forum just type in alignment in the search and you will find them. as far as who to get to do the work you need to find a good tire shop that does alignments or a truck shop that does them,some large ford dealers also can handle that.
lbrunning is offline   Reply With Quote
Old 04-06-2015, 07:57 PM   #3
Get the alignment set to the specs you will find on this forum then see if it does what you need before spending money on another stabilizer. Also make sure your factory stabilizer is aligned properly. When I had my unit alignment done the tech said he also adjusted the stabilizer properly which according to him, is often not setup correctly. You have to expect some movement in high winds because the big flat sides act like a sail.
ATVer is offline   Reply With Quote
