You likely have a model 21 SCS/Frigette (coach step) like my 2006 Sunseeker.
According to the manual the yellow wire from the 4-pin connector near the controller should have a 6 amp fuse or circuit protector to the fuse panel.
Also, from the positive post there are 2 wires with protection.
Wire 1 - looks like a red wire, rather hard to tell from the manual, goes to the 4-pin connector, location above, and this wire has a circuit protector although it may not be a replaceable fuse.
Wire 2 - the other wire from the positive post goes to the inside power switch and it is marked as having a 6 amp circuit protector, possibly a replaceable fuse. In my coach battery compartment all wires are red, and the manual does not call out the color of this wire but in my case it has to be red, likely yours is too.
Good luck. My controller and motor has gone out 2 or 3 times since I bought it.
Chris
2006 Sunseeker 2860DS Ford V10 5 speed with Tow/Haul
Winegard T4 In Motion Satellite Dish
Furion Rear Camera, RecPro 70" Recliners
Mohawk Luxury Vinyl Plank Flooring
2013 AWD Acadia Denali, Blue Ox Equipped
