02-08-2015, 10:00 AM
#41
Commercial Member
You're very welcome. There is a shift taking place at Forest River right now. I think you'll see a lot more of our employees become more accessible.
02-08-2015, 01:43 PM
#42
Originally Posted by bclemens
1. You can order whenever you want and just specify that you want 2016 model year.
2. We won't change any colors until the mid model year refresh in September.
3. Chassis will not affect any changes to our portion.
4. No major changes expected form Ford or Chevy (that I know of).
5. No Major changes expected on our end either, however I am always tweaking little things (adding LED lights to the sewer area, changing trim or components). If I can make the product more durable or useful I don't ever wait for model change.
This info really helps us, also, as we want to take advantage of the new items when we time our order. Also, really hoping that the dual recliners become an option in place of sofa in the 3030S. I'm sure you will keep us all informed as things are added.
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
02-09-2015, 12:15 PM
#43
Mr. Clemens! Would it be possible to order the couch in the 2650S in cloth? What would the choices be in cloth? We will order the Maple wood and Spice décor options. Would it blend with the non ultra leather cabin seats? Thanks Bud
02-09-2015, 01:07 PM
#44
Actually meant 3050S, not 3030S. I didn't mean to invent a new model....
Born April 18, 2016
GO DUCKS !!
02-09-2015, 01:43 PM
#45
Understood!! Mr. Clemens please disregard my question on the cloth option couch. We looked at photos on line and saw the dinette in cloth thinking it would be a solid color! Can a unit with the 15K BTU A/C IPO 13.5K A/C be converted to a heat pump? Can you describe what would be involved please! We may have found a unit!!
02-09-2015, 04:18 PM
#46
Commercial Member
Actually yes. If you request it in fabric, it would actually be the "Valance Leg" NOT the patterned fabric.
As for converting to 15k, that would be up to the dealer. Should be possible as the opening is the same. Not sure about the wiring however. I think the heat pump T-stat has a few more wires.
02-09-2015, 05:26 PM
#47
Thank you! Here is what is confusing!! When I received the build sheet from dealer it showed #1635 - 15K BTU A/C IPO 13.5K BTU A/C. I called sales manager on this and he said it did not have heat pump but may be able to add heat strips. I am concerned with this. Your thoughts??
02-09-2015, 05:28 PM
#48
Commercial Member
If the build sheet says 15k, then the dealer is probably confused. The only 15k that we build has the heat pump.
02-09-2015, 05:45 PM
#49
My wife just said you are a HERO!!!! How would I know for sure? Would the T-Stat show anything?
02-09-2015, 05:51 PM
#50
Commercial Member
T-stat would say "heat pump"
02-09-2015, 05:56 PM
#51
You are a "HERO"!! Thanks for everything..............will let you know in about 10 more days!!! Woooohooo!
02-11-2015, 04:09 PM
#52
Would anyone like to comment on preferences between Sunseeker 2650S versus Forester 2651S? I know what the standard features and options are but is there any other differences in the coach, chassis, handling or ride?? Thanks BUd
02-11-2015, 04:18 PM
#53
Commercial Member
same coach, no difference other than features. they are built on the same chassis down the same line.
02-11-2015, 04:28 PM
#54
Thank you Sir! After reading a few posts on the Forester it sounds like the FW drain is a little tough to get to compared to the Sunseeker. Has that design changed any?
02-11-2015, 04:48 PM
#55
Commercial Member
same on both...if there is a difference it was probably model year based not brand based.
02-11-2015, 04:59 PM
#56
Owner stated he had to raise the bed platform to get to the drain where the Sunseeker was in a exterior compartment door??
02-13-2015, 10:09 AM
#57
Commercial Member
could be...but it would be the same way on Forester for the same floor plan.
