Old 11-26-2016, 12:53 PM   #1
Suburban furnace not working Urgent help needed
2016 Sunseeker 3010ds. First time out in cold weather with this camper. Furnace will light and run for a couple minutes and then flame goes out The unit will try and relight but fails. Please help it is getting cold.
izzaboomer is offline   Reply With Quote
Old 11-26-2016, 01:19 PM   #2
Propane tank have propane and turned to on position? Battery disconnect in the on position?
lexstone is offline   Reply With Quote
Old 11-26-2016, 02:04 PM   #3
Evereddie's Avatar
Check for bug nests in heater vent.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 11-26-2016, 02:23 PM   #4
Flybob's Avatar
Also check heat ducts/vents. If they are partially blocked, the furnace will overheat and the over temp will shut it down. There are know instances of the flexible heat ducts being crushed by wiring or frame members.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-26-2016, 03:15 PM   #5
propane on battery disconect on no blocked vents. All comes on heater working great small boom and flame goes out. will not relight
Old 11-26-2016, 05:30 PM   #6
Light a burner on the stove and watch how it acts when the furnace starts. If the flame on the stove goes low or out, you have a propane supply issue.
Days Camped: '18=51 '19=58 '20=110 '21=15
Old 11-27-2016, 01:30 PM   #7
Send a message via Skype™ to stillontheroad
I had the same problem so I joined the RV Repair club for $6.00 (annual membership) today to access all of their on line videos. Black Friday/Cyber Monday deal. Just going to watch the video now.
stillontheroad is offline   Reply With Quote
Old 11-27-2016, 02:33 PM   #8
Trouble is I am at a campground with very limited reception. Do you remember what you did?
Old 11-27-2016, 03:02 PM   #9
RudysWorld's Avatar
Maybe a mud dauber in exhaust or burn chamber, if not a propane problem.
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 11-27-2016, 05:13 PM   #10
Sticky regulator?
markb422 is offline   Reply With Quote
Old 11-27-2016, 05:51 PM   #11
Evereddie's Avatar
Did you do the "turn on a stove burner and then the furnace" test?
2018:16
Total 239
Old 11-27-2016, 08:32 PM   #12
[QUOTE=izzaboomer;1370989]Trouble is I am at a campground with very limited reception.
I knew that there was propane because it would start then go out. Then I had to access the control board... On mine it was difficult to do because the only way to get at it was to slide the whole unit out on the inside (I have a 2012 8280 Rockwood fifth wheel and the furnace is located under the oven)..Now the problem ... I had to disconnect the propane and that can be a dangerous process...I would not recommend that. Depending on the year of your unit, there may be an access panel right where the furnace exhausts, If there is, take out the screws and you should be able to access the control panel. Near the control panel there should be a small box with a little flipper on it. It may be that the flipper is stuck.. This unit works as follows.. When your furnace fires up, the fan should start but if the chamber gets too hot the flipper will activate and shut down the flame... Hope this helps a little. http://www.forestriverforums.com/for...ies/crying.gif
Old 11-27-2016, 09:02 PM   #13
TimVWulp's Avatar
4. Burner ignites, but goes off and into lockout:
a. Check to be certain that flame sensor is over slots in the main
burner and that the main burner flame is burning against the tip
of the flame sensor - adjust by bending sensor probe. NOTE:
Sensor probe should be in the inner blue cone of the burner
flame (approximately 1/4" t o 5/16" above burner).
b. Burner still goes off and into lockout - check wire connections
at flame sensor and at module board.
c. Wire connections OK - check continuity through flame sensor
wire.
d. Continuity of flame sensor wire OK - check with micro amp
meter in series with flame sensor and flame sensor wire to be
certain that the flame sensor is generating at least seven
micro amps within seven seconds after the burner is ignited.
Connect meter as follows: (+) to sensor wire, (-) to sensor
probe. Adjust position of sensor probe, check for carbon
deposits on sensor probe if reading is less than seven micro
amps.
e. Flame sensor circuit generating at least seven micro amps,
but burner still goes off and into lockout - replace module
board
http://www.forestriverforums.com/for...?do=file&id=67
Above is a link from the library in the green bar at the top of the page. open the link and down load it and open the down load. the information I coped above is on page 29 of this link.
A common problem with the flame rod in your home or RV furnace is that it corrodes with white rust or red rust. The rust acts as an insulator to the micro amps and needs to be removed. This can be cleaned off with steal wool or 400 grit sand paper or a new flame rod so the rod has good contact with the flame to pass the micro amps.
Hope This Helps Tim
TimVWulp is online now   Reply With Quote
Old 11-27-2016, 09:12 PM   #14
Bluepill's Avatar
Good thread here also:
http://www.forestriverforums.com/for...tml#post327988
Old 11-28-2016, 09:24 PM   #15
I'm suspicious of the "small boom" statement. You should never have this because the only way you get a small boom is a gas explosion. Gas explosions occur when propane spreads around the mixing tube instead of travelling through it. Propane exits an orifice, mixes with air then is transported to the burners. If some of the propane does not go to the burners, you can get the "small boom" when the gas concentration rises to the point where the burner flame ignites it. This explosion will probably shut down the burner, exactly what you are seeing.
You should verify that the tubing between the orifice and the burners is free of obstructions.
Phil
pmsherman is offline   Reply With Quote
Old 12-08-2016, 12:13 AM   #16
TimVWulp's Avatar
Hi izzaboomer looks like I ran into the same problem you are or were having with intermittent furnace operation. The 2 sons came home to visit and took over living room. So I went out to the TT turned on the television and furnace. Furnace worked for the first hour and then started with the fun and games of not playing nice. IT would lite the burner and go out 3 time and then lock out. I cleaned the flame rod NO change! Check the furnace over for how bad it was going to be to pull the furnace so I could get to the control board. After looking it over I called the dealer he said to bring it in. Brought it there last Thursday and got it back on Wednesday (to day). Dealership replaced the control board under warranty from suburban less than 2 years old and now works like new.
Hope This Helps Tim
Old 12-08-2016, 08:54 AM   #17
Thanks guys for all the info. Turned out to be muddobbers. I had put screens on right after purchase so must have happened at dealership. Good luck proofing that. I ate the cost.
furnace, suburban
