Old 10-28-2020, 06:14 PM   #1
Sumo Springs on Forester Model 2801 GTS?
So my unit just has storage cabinets over the cab and no bunk thus I don't carry the weight of those that do. I phoned SuperSprings.com today and they honestly felt like adding their rubber "springs" to the front of my unit might give me too much of a stiff ride to be an improvement.
Has anyone with my model added these to the front or back of their unit? (I have added the Roadmaster steering stabilizer a couple of years ago that tightened up the steering but not the ride, obviously.)
The Sumo Spring product talks about minimizing some of the sway you get when a big rig passes you which would be nice to eliminate if possible. Thanks for your input.
ArkRVHog
2018 Forester Model 2801 GTS
Little Rock, AR
Days Camped 2020 - 29/Days Camped 2019 - 71/
Days Camped 2018 - 49
ArkRVHog is offline   Reply With Quote
Old 10-28-2020, 06:37 PM   #2
Kanadian Kamper
kenandterry's Avatar
I also have a Trekker cap unit......no beds over the cab.
What improvement are you looking to accomplish?
Itís an RV....not a sports car.
My rig has air ride suspension in the rear......yours?
Just wondering.
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 10-28-2020, 07:03 PM   #3
Dcbenny's Avatar
I have owned my 2800QS GTS for 2.5 years about 2 months ago I added the Summo Springs on the front and what a difference in the drive, the biggest improvement I felt was the front end doesn't dip and roll as it used to. I wish I did this at the same time I did the front wheel alignment when I first purchased the MH that's how much I enjoy the drive
Don & Liz B.
Pink Retired Greyhound
2016 GTS 2800QSF
Dcbenny is offline   Reply With Quote
Old 10-28-2020, 07:05 PM   #4
Just wondering.
From my original post - The Sumo Spring product talks about minimizing some of the sway you get when a big rig passes you which would be nice to eliminate if possible.
ArkRVHog
Little Rock, AR
Old 10-28-2020, 07:08 PM   #5
Excellent...just the validation I was looking for. Can you confirm the exact model number of the springs you put on? Did you do it yourself?
My DW and I love our 2801 (which as you know isn't manufactured anymore under the Forester brand.) It's the perfect length, room for everything we need, and tows our CRV easily.
ArkRVHog
Little Rock, AR
Old 10-28-2020, 07:09 PM   #6
Tombsy's Avatar
I believe you should have Ride-rite airbags on the rear already. I do on my 2015 2801QS. I usually run about 75 psi. I recently added front and rear sway bars, Bilstein shocks, and a steering stabilizer that all come on the newer units I think. It wasnít terrible before the upgrades but itís great now.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 10-28-2020, 07:13 PM   #7
Dcbenny's Avatar
My 2800 is the Sunseeker sister to your Forester 2801 I will go back and see what model I purchased from Amazon took me 20 minutes to install. If you go to You Tube lookup RV Habits, Lou has the same as you and he does a great job explaining MODS he has done. Have have stolen several of them LOL
Don & Liz B.
2016 GTS 2800QSF
Old 10-28-2020, 07:18 PM   #8
Dcbenny's Avatar
Here you go
SuperSprings International, Inc. SSF-106-47 | SumoSprings Front for Ford E-150|E-250, Ford E-350|E-450, Mercedes-Benz Sprinter 2500|3500
Don & Liz B.
2016 GTS 2800QSF
Old 10-29-2020, 10:04 AM   #9
Yep...I do have the Ride Rite air bags...try to start with about 60 psi on trips. Do yours seem to lose pressure after a week or so?
Appreciate the model number of the front Sumoís you installed.
Old 10-29-2020, 03:19 PM   #10
sgtlm17's Avatar
I installed the Sumo Springs on the front of my 2016 2801 GTS Forester. The difference is amazing. I would recommend it to anyone. Much less sway and dipping in the front end. The install was as easy as it gets. All you need to do is try and find a 10mm socket which for some reason is always missing from my set. A thumbs-up upgrade that I would do again.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 10-29-2020, 05:52 PM   #11
Dcbenny's Avatar
Lou didn't know if you saw post 7 LOL
Don & Liz B.
2016 GTS 2800QSF
Old 10-29-2020, 07:52 PM   #12
Tombsy's Avatar
They did slowly lose pressure and it was a real pain checking and filling them in the compartments. I installed a Wireless One, a little automatic on-board compressor with a remote that adjusts and displays the pressure. It was a bit of work but one of the best mods Iíve done.Click image for larger version
Brian
Old 10-30-2020, 07:50 AM   #13
sgtlm17's Avatar
I did see your post, thanks Don. For my rig which is a 2016 E450 I also used Sumo Springs part number SSF 106-47. Hope this helps.
2011 Jeep JK Toad
Old 10-30-2020, 07:53 AM   #14
They did slowly lose pressure and it was a real pain checking and filling them in the compartments. I installed a Wireless One, a little automatic on-board compressor with a remote that adjusts and displays the pressure. It was a bit of work but one of the best mods Iíve done.Attachment 242193
Wow...I didn't know there was such a contraption available...that is NICE. Thanks for sharing!
ArkRVHog
Little Rock, AR
2801, forester, gts, sumo, supersprings
