Old 08-19-2018, 08:50 PM   #1
sun seeker 2250 black water flush valve
Does anyone know if there is a black water flush valve on a 2012 2250 sunseeker? Apparently, some Rv's have them and I have never seen one. I bought the rig used two years ago and just don't know. Thanks in advance.
Brad and Janie
2012 2250sl Sunseeker
North Texas Retirees having fun
popshumphrey is offline   Reply With Quote
Old 08-19-2018, 09:10 PM   #2
Can't find your exact model, but other 2012 Sunseekers are advertised having them.
You have an inlet to hook up your city water. Do you have another inlet that you don't know where it goes? There's usually a large caution label for black tank flush saying 'do not use tank flush valves.....' near the connection OR a black tank label. (Do not use until you know how to use it.)
A picture of your city water and other connections would help.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-20-2018, 12:10 AM   #3
Splitshaft's Avatar
My 2018, 2250LE does not have a flush valve and it is not even an option from Forest River on that model. If the question is about the black tank “waste valve” to empty the holding tank, mine is on the curb side of the coach, while the gray valve is on the street side of the coach.
Splitshaft is offline   Reply With Quote
Old 08-20-2018, 07:39 AM   #4
There is only one connection on the drivers side, for city water. Have not seen another connection yet.
Brad and Janie
Old 08-20-2018, 09:13 AM   #5
Then you probably don't have it. They do make aftermarket devices to flush the blackwater tank.
Old 08-20-2018, 10:36 AM   #6
Total Loss's Avatar
No they do not have one being the lower end unit.
I added one to mine. I already had to change the cheap plastic one way valve in it but it works well. Plug any hose into it. I put the nozzle attachment point on the end wall next to the right side rear frame rail. Works for me with my dump station at home. May want to run it over to the left side of the rig for easy hookup at an RV park though.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 08-20-2018, 03:01 PM   #7
My 2014 3010DS has one. It was standard on that unit.
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is online now   Reply With Quote
Old 08-20-2018, 05:04 PM   #8
geeman53's Avatar
Our 2016 2250 SLEC came none , we did the same as Total Loss . We love our poor sister MH ! What FR left out ,we added . Custom is my middle name !
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
Old 08-21-2018, 04:36 PM   #9
On 2013 2650S... Click image for larger version
sask is offline   Reply With Quote
Old 08-22-2018, 06:51 PM   #10
Thanks folks. I love the size of the 2250 even if it is "lower end". It has what I wanted. What I did was order one of the sewer attachments with a shutoff valve from camco. Looks like it will work. Has anyone ever used one? It has the same kind of slide shutoff as on the black and grey tanks and a hose attachment. It is a Camco rhino blaster.
Brad and Janie
black, black water, flush, valve, water
