Old 04-26-2018, 06:39 PM   #1
Sunseeker 2650 bedroom plug not working
This is a FYI in case you have a 110 plug-in that does not work.
We had a 110 plug in the bedroom that stop working. I checked breakers and all were on. I started tracing back the 110 circuits and found the culprit behind the outside water heater access door. There was a 110 plugin there that had current coming in but not going out. The plug had quick connectors that sliced the wire rather the screw terminals. I turned off breaker and pushed the wire deeper into the connector and power was restored.
In summary a plugin may have power but connection might not be allowing current down the line to the next plugin.
sask is offline   Reply With Quote
Old 05-01-2018, 07:52 PM   #2
Frankie Z's Avatar
Good to know
Frankie Z is offline   Reply With Quote
Old 05-01-2018, 08:51 PM   #3
Oops... it actually behind the fridge access panel.
bed, roo, sunseeker
