Old 07-21-2015, 07:55 AM   #1
Sunseeker 2860DS question
I posted this on another forum also, but I only got one responce, so I hope no one minds, Thank you again gmacklem.
I'm hoping Joshua or Bclemens could weigh in on how it's designed to work.
Just a quick question, we looked a a Sunseeker 2860DS yesterday. We like the floorplan and layout and just wanted some info from current owners. We noticed the bedroom slide was out a little farther at the bottom than the top (~1/4" +), was told that because it was driven from the bottom, it was for a tight closure/seal when closed. I also looked at the FG roof which I like, but noticed the seam/trim on the roof at the edge and wanted to know if this caused puddling or poor drainage.
Freelander is offline   Reply With Quote
Old 07-21-2015, 08:03 AM   #2
BendOrLarry's Avatar
I have a 2009 2860DS No issues with either of the slides or roof leaks. Dont know if this helps you or not.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 07-21-2015, 09:28 AM   #3
trdutch's Avatar
2014 2860DS
I know what you are talking about because I noticed both of your questioned areas.
No problems with either slide.
I'm very anal about slide care and they havent let me down in a year of trips.
I lube the gear tracks under the slides with anti corrosive spray
I lube the rubber seals with the foam lubricant.
I clean and wax the slide sides and especially the top under the topper so there is no debris and smooth operation.
I store on a slightly unlevel spot so roof always drains to a corner gutter drip and so far camping I always have a nice air conditioning drip off one of the corners.I keep the corners free of gunk and black buildup.
No problems with pooling
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 07-21-2015, 05:14 PM   #4
same on mine no issues as of yet
retired on a mountain is offline   Reply With Quote
sunseeker
