Originally Posted by ScottBrownstein
Why do you need to access the line to blow it out in freezing weather? In addition, the valve is at the bottom of the reefer, not where the line enters the freezer. You need to blow the water out from the bottom.
Sorry of I wasn't clear. I just need to replace the leaking line. I used to blow it out from the bottom, but now it's turned off, cause it has a hole between the valve and the ice maker. Thanks
