Actually, no. Reason was that according to my research, unless you go Greyhawk or Redhawk by Jayco, you get the same ride/drive in all Class C of comparable length/weight. With the exception of the rubber pucks between the frame that Jayco uses, everything else is bolt on after market..... track bar, HD sway bars, steering stabilizer, shocks.
Gary
 2017 SunSeeker 3010DS
