I have a 2011, 3170DS. The switch above the fridge is to turn the water heater on\off. If you want to operate on electric remove the metal cover to the water heater outside. There is a small-black on\off switch behind this cover above the anode rod, this is for electric heater operation. Remeber to turn the propane off, it is located outside so that you don't accidentally operate them together.
2011 SunSeeker 3170DS
