07-08-2020, 10:40 AM
Sunseeker AC Not Cold
Hello Forum'ers,
Good friends of mine have a 2013 Sunseeker C, 31 ft. and their rooftop AC is only blowing cool. It cannot cool down their rig in mid 80-degree temps. They had a friend come over that does HVAC work but was perplexed that there are now access ports or such to test the unit out. Any suggestions I can pass along to them from Sunseeker owners, or I guess RV'ers in general on what to look for. They called a couple of places in the Buffalo, NY area but it approaching mid-summer and everyone camping because of Covid-19, they were told weeks before they could get their rig in for a service call.
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
07-08-2020, 11:08 AM
These R/V rooftop A/C units are what are called 'sealed units' and have no service ports.
They are made to not be serviced easily.
There have been several lengthy threads recently on the pros/cons of adding a service port to check the freon level.
If it is a Dometic unit, several models were under a warranty replacement program.
Unfortunately, they are simply designed to be replaced.
07-08-2020, 12:35 PM
Sounds like something out of the world of camping. Thanks 5picker.
07-08-2020, 12:37 PM
Well... not only the world of camping... back in the day, my father made a very good living as an appliance repairman. Today they are simply delivery men for new/replacement units. It has become a 'throw-away' world!
07-09-2020, 08:10 PM
Happy Camper
I added a service port to my main unit, serviced it back up and have enjoyed cold air for three years so far. Cost a lot less and easier than replacing the whole unit.
07-09-2020, 08:33 PM
Make sure to clean the coils + the fan blade's + filter
Some people over look the easy things
Do mine every year, sometimes twice
You can add service port's , a HVAC guy may charge a couple hundred , if you know him .more if it's a big company.
My 15000 btu unit will drop 20 degrees from outside temp .
95 out 75 in
07-10-2020, 11:33 AM
Besides being able to do analysis, what do the service ports due? Is this to add freon, or whatever coolant is being used today?
07-10-2020, 04:42 PM
Yes the port's are to charge the system , or test for leaks .
If you have no freon in the sealed system you have a leak somewhere .
To find the leak you can look around the piping . if you see a oily substance it's your leak .
If you add port's to the system have a HVAC guy help you , high pressure in the piping . you can do a vacuum test with the new port's , if it stays at 500 microns or 1000 for a half hr. That would tell you no leak . well were did the gas go to in the first place .
If you add port's and you cut the pipe and there's a change in the system 300lb. you can get hurt bad , frozen fingers , lost of eyes , hire a HVAC guy . or buy a new a/c unit
To add port's and test + recharge could be half the cost of a new unit .
07-10-2020, 09:58 PM
Super info guys I'll pass along to my friends.
Yesterday they got someone to look at their rig, waiting to hear from them if the problem was discovered or resolved
07-10-2020, 11:04 PM
Brake is on left
I had a unit replaced under warranty thankfully. They actually left the old unit in the garage of the TH. I bought saddle valves to pressurize the unit and find the leak at the evap coil. Brazed it closed and installed permanent service ports to evac and charge. So now I have a 15k unit ready to go.
07-11-2020, 10:30 AM
Smarty! Don't you just love it when things go tour way?[emoji16]
2018 Forester 3011 DS
