Sunseeker ceiling light lens removal
Just did that to mine! Easy once you know how. Take a small, flat prying device of some kind (I used a nail file) and insert it between the plastic lens and the frame around the lens, then pry it out. It won't (shouldn't!) break. Mine didn't. They pop right out. Be cautious not to insert the tool in very far, as you will (I did) contact the electrical circuit board and short the light out.
Since I was replacing the entire light assembly anyway with a better light, no harm done.
Good luck!
