Old 03-01-2016, 07:35 AM   #21
Wolverine 1945's Avatar
I believe the bottom of our screen door has like a brush on it ???
Bottom of the door does not touch the step or the threshold !!!
Wolverine 1945 is offline   Reply With Quote
Old 03-01-2016, 09:15 AM   #22
Delco Bobby's Avatar
Yup, mine has a doir swedp brush, no factory installed foam.
Since using my stuff the foam in the stairwell method I have not heard a squeek or rattle in over 400 miles of driving. Much of that on rough roads.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 03-23-2016, 02:42 PM   #23
BEFUDDELED MEMBER
Originally Posted by Kchula-Rrit View Post
The better half laid a bead of silicon RTV all around the door panels and window, inside and out. This cut out virtually all noise from the door.
Now for the crashing sound from the back...
K-R.
Did this within a few days of the first trip.
13,SUNSEEKER 3010
RETIRED / New Mexico
D KZ5PZ - EXTRA -DW K5ZPZ - GENERAL
Viet combat vet USNR
DAV, VFW, CCL. SASS
shooter2 is offline   Reply With Quote
Old 03-23-2016, 04:12 PM   #24
Another source of door noise...
On last trip DW noticed that our door closer was hanging out of the vehicle. The screw that holds it to the door jamb had backed out. I reinserted and tightened it.
Afterwards had several short trips where I didn't bother to place my foam vibration damper in place. See previous post. Eventually realized that the door was rather quiet.
Check your door closer screws. I was lucky that all the hardware stayed with the loose closer.
2018 Ford F-150
Old 04-05-2016, 02:21 PM   #25
2015 Sunseeker 2300
We still have wind noise and it makes traveling miserable wish we could find where it is coming from
Gingsnap is offline   Reply With Quote
Old 04-05-2016, 03:09 PM   #26
We also have wind noise that bothers me. Some is probably the nature of the beast.
I have been saying since day one that it sounds and feels like a window is open but all are closed.
I plan to investigate the cab over windows from the outside to see if There are any gaps not visible from inside.
Can I put an extension ladder against the side of a Sunseeker?
2018 Ford F-150
Old 04-05-2016, 03:25 PM   #27
2015 Sunseeker 2300
I do not think our cab is sealed well and I do not think the door is sealed at all the dealer just put some tacky silicone on it but it did not help you can see daylight around out door dealer keeps saying it is because they use clear silicone it is just a mess I hate riding in it
Old 04-05-2016, 03:46 PM   #28
In this thread, If you have not already done so, read posts #9, 11, 12, 14 and maybe 20 if it applies to your door.
One or all may help.
2018 Ford F-150
Old 04-06-2016, 05:28 AM   #29
I see no problem with a ladder against the side,,, I extend mine up far enough so that it is the roof level,,, and I pad mine with foam pipe insulation !!!
Old 04-06-2016, 08:33 AM   #30
Thanks. I have foam bumpers on my ladder. Now maybe I can wash the roof.
2018 Ford F-150
Old 04-06-2016, 08:55 AM   #31
Have Fun !!!
What ever you do,,, do not back off the roof !!!
Old 04-06-2016, 06:27 PM   #32
Have Fun !!!
According to my doctors I am not allowed on the roof and on ladders due to my imbalance issues. If I got on the roof I would probably breaks stuff, fall through and or fall off.
Your comment is both funny and appropriate for me.
I plan to use a brush on an extension pole and hope I don't forget to climb down the ladder when done.
2018 Ford F-150
Old 04-07-2016, 06:30 AM   #33
I hear ya Bobby !!!
I used a Painters Adjustable Pole,,, unless I could hire one of my Grandsons !!!
Old 04-07-2016, 07:54 AM   #34
Good idea, I didn't think of a painters pole. That will be an improvement over my old car wash pole.
Thanks.
2018 Ford F-150
Old 04-07-2016, 08:32 AM   #35
Thanks.
Should be just long enough to reach all the way across ???
Old 04-07-2016, 07:38 PM   #36
Previous Member
You can install a rear ladder for less the the cost of a side ladder you
may be using Camping
World for around 100.00
Get layouts from Sunseeker of sear wall.
allan kay is offline   Reply With Quote
Old 04-07-2016, 08:06 PM   #37
Previous Member
I install it above the rear bumper between the tail
Nights and rear window
You
Old 04-07-2016, 08:09 PM   #38
Previous Member
You can get the lay for proper exact location and print out for bolt location from FR.
For your RV.
Old 04-08-2016, 09:00 AM   #39
Don't think it would be a Good idea to install a ladder on a 2500TS,,,
With a rear Bedroom Slide !!!
LOL !!!
Old 04-09-2016, 01:19 PM   #40
I hear ya Bobby !!!
Bought a painters pole at wallmart yesterday. They have two sizes both more than enough for my purposes
2018 Ford F-150
door, noise, sunseeker
