Old 04-22-2019, 01:02 PM   #1
Sunseeker screen door
Just bought a 2005 Sunseeker. Doesn’t have a screen door. Having trouble finding a screen door without buying the complete door unit. Ugh. Does anyone have any solutions.
Help.
SPD
spd1292 is offline   Reply With Quote
Old 04-22-2019, 02:42 PM   #2
Garrette's Avatar
Deleted duplication. Well it looked like a duplication reposted.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 04-22-2019, 03:08 PM   #3
Garrette's Avatar
Also look at etrailer.com for screen door parts. Did not see screen doors but I would call. Also, search for RV salvage yards. Keep us posted.
Old 04-22-2019, 03:22 PM   #4
Garrette's Avatar
My 2014 3170 door was built by Lippert. Do you have a door label at the bottom door edge, hinge side?
Might try Lci1.com
Do not know if we have the same door but here is my sticker and my door and mounting. Hope this helps. Click image for larger version
ID:	202443Click image for larger version
ID:	202444Click image for larger version
Old 04-24-2019, 10:07 AM   #5
Wolverine 1945's Avatar
Your probably s out of luck
Unless you replace the entire door !!!
Wonder what happen to original door ???
GOOD LUCK !!!
Wolverine 1945 is offline   Reply With Quote
Old 04-24-2019, 10:24 AM   #6
Garrette's Avatar
Do not discount RV salvage yards. Found this.
https://www.rvbasics.com/techtips/rv...ent-parts.html
Do you have a story for the missing screen door? Might be a lesson for all of us. Keep us informed of your outcome.
Old 04-24-2019, 10:38 AM   #7
RV Salvage Yard is a GREAT Idea n!!!
Also look for Mobil Home Yards !!!
Old 04-24-2019, 03:09 PM   #8
The door was MIA when I bought it. Got it at a dealer and they had no clue. Oh well s happens. I will check salvage yard. Good idea.
Old 04-26-2019, 07:21 PM   #9
Garrette's Avatar
Keep use informed on your outcome. Hope it is positive. Good luck.
Old 04-28-2019, 07:47 PM   #10
Next screen door option haha
Spent a lot of time on the phone. Lippert makes the screen doors they’re using now. The company they used in 2005 is out of business. Oh well. Talked to the folks at Lippert. They would make a complete rehung door $$$$$$. So I’ll figure something else out. They’re retractable options. Can even get one cut to size.
That’s where I am right now. Thanks for the suggestions and help.
SPD
Old 04-29-2019, 10:48 AM   #11
SPD
Have you ever thought about buying an old Wooden screen door and cutting it to size ??? That is what I did to our laundry room door that goes into our garage ! They do not work well where they get wet, but not a bad option in a dry position ??? I bought ours about 25 years ago, so do not remember cost ??? Very low I believe ???
Old 04-29-2019, 01:04 PM   #12
Garrette's Avatar
As a stopgap, I would try one of those magnetic screen doors. Walmart and Amazon has them and fairly inexpensive.
I would also post pictures and info on the for sale forum and on iRV2 as well. Someone may have a frame. Also look for mobile home supply stores.
Keep us informed of your solution.
saunseeker, sunseeker
