Originally Posted by Mbear12
We bought it from the original owner ...I don’t think it ever closed completely. The fourth bracket is six inches away from matching....there are no brackets on the rear half of the slide...so it closes fully. At the very least I need to grind down the bolt heads a little so they won’t bind on the top of the coach bracket.
Are these the seat belt anchors?
What purpose do the brackets have if they are only on the front of the slide? Maybe to help secure the slide.
Suggest not “grinding”. I am thinking there is a couch above the brackets. They are for safety standards if passengers ride in the slide.
I would remove the brackets on the slide that do not line up.
At that point you can fully close the slide and adjust it properly. Then you can reinstall the brackets you removed in the correct location.
Slide out alignment depends on what mechanism is in use.
Suggest not removing any brackets that are bolted to the frame.
You can delete your duplicate post and your post in the slide leak thread. Suggest you focus here and get more opinions.
