Sunseeker Squeak Solved
Our 2015 Sunseeker 2650s-cdw developed a nasty, annoying squeak right behind the driver. Turns out it was caused by 4 loose screws on a black plate that is part of the slide. There are 8 screws, 2 rows of 4, one of the 4 which had almost worked itself out, with the others being quite loose. Very odd. Re-tightening the 4 attached to the motorhome side eliminated the problem. The screws were not stripped and seated nicely when tightened. I suspect they weren't tightened properly upon assembly. Still, I am sure everyone can appreciate the relief when a squeak is silenced.
