09-07-2014, 04:18 PM
Puzzlme
Tail light filled with water.
2013 3010 DS
Just completed a 9000 mile road trip and encountered some great weather. After the occasional rain I noticed that the RR Tail lights were filled with water. I drained and reinstalled the 3 lenses thinking they perhaps hadn't been tightened on installation. After the next rain storm, my tail, brake and signal lights were out. Seems the lenses filled with cold rain water and the hot bulbs exploded on contact. For the remainder of the trip I drained them whenever it rained.
Any idea why this might be happening or what I can do to prevent this from happening again?
I have made sure there is no debris around the seal.
09-07-2014, 06:48 PM
There have been some reports of problems like this. You may need to apply some caulking to the top edge of the tail light lens. Or another solution is to change the taillights to LEDs. They are much brighter and a sealed unit. This is what I did:
Top one is new LED. Bottom one is not yet changed. Here they are with LEDs for taillights and back up lights:
2012 Forest River Sunseeker 2300 Chevy
09-07-2014, 07:06 PM
Had trouble-------------
Had trouble with my rear running or clearance lights getting water inside, the ones across the top. Removed the red lens, cleaned inside. Drilled small hole in bottom edge of lens for drainage, re-installed lens, caulked
across the top seam to keep water out.
No more water.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
09-07-2014, 08:17 PM
Common problem for a couple model years. I used bulb grease across the lens tops and drilled small holes to drain. Others have caulked or used RTV but that can make the lens hard to remove latter. As long as the water can't build up and splash onto the bulbs you should be okay.
11-07-2014, 11:11 AM
2013 Sunseeker 3170DS FD
This happened to me as well after the first trip in the Sunseeker 3170 DS. Of course our first trip w/out brakes and turn signals was a bit terrifying, thankfully the wife was with the kids in the mini-van behind us. The dealer fixed it free of charge. I also re-caulked over the dealer. Not sure if it was water or bad lights but it sure wasn't right!
11-10-2014, 12:29 PM
Commercial Member
I am told it is not a problem...apparently it is designed that way. I sent this up the river to the engineers at Bargman basically saying I was tired of the complaints. They call it a "drain and dry" design. They say if they seal it and water does infiltrate, then the water has no place to drain.
11-10-2014, 07:38 PM
The LED conversion is a great solution to the problem after-market. Could Bargman produce a product that could be used as an original install? I switched to LEDs as a safety factor. Almost got rear-ended on Interstate when stopped for crash. Car turned at last second and ended in the ditch beside my passenger door. The LEDs are 10 times brighter than the incandescents that come on the MH. The LED backup lights are also very bright which is great for backing into campsite in the dark. (See my pictures posted above.)
11-10-2014, 10:41 PM
We replaced our 3170 rear lights with the Bargman LED lights show in RvBill3's above post. Ours have no reflective properties, so we added stick on reflectors from an auto parts store. If you are careful, they look like they came on the unit.
11-10-2014, 11:33 PM
Oklahoma Proud
They are right. It condensates inside the lenses from the moisture in the air with the warmth of the bulb.
We use to have alot of problems with the clear aftermarket lights that were real popular 15 years ago, holding water and discoloring or eroding the chrome inside. Our fix was to drill an 1/8th inch or smaller hole in the lower corners of each lense. Never had an issue and I did it proactively on every set i installed.
I dont think you have to go as big as an 1/8, but give it a shot.....unless your wanting the upgrade
11-10-2014, 11:37 PM
Reminds me of a joke I heard years ago....Engineers design it...common folk make it fit or work! LOL
11-11-2014, 08:38 AM
Engineers design what works, purchasing agents buy what's cheapest, then marketing sells it for slightly less than the good design.
Then engineers get blamed because the designed-to-a-price junk fails.
Retired engineer
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
11-11-2014, 08:55 AM
Originally Posted by RvBill3
The LED conversion is a great solution to the problem after-market. Could Bargman produce a product that could be used as an original install? I switched to LEDs as a safety factor. Almost got rear-ended on Interstate when stopped for crash. Car turned at last second and ended in the ditch beside my passenger door. The LEDs are 10 times brighter than the incandescents that come on the MH. The LED backup lights are also very bright which is great for backing into campsite in the dark. (See my pictures posted above.) 100% Correct! LEDs so (The OTHER GUY) can see YOU! Youroo!! PS and the LEDs are Totally sealed/No Water!
OK!
11-11-2014, 09:23 AM
Retired engineer
Very true.
Another retired engineer.
11-11-2014, 09:51 AM
Infractee
Spurious logic...
If it is sealed, water can not infiltrate, if it was not possible to properly seal a lens housing then every car going down the road would look like it has 2 red fish tanks in the back.
As for the lens filling up from condensate... sealed lenses would also solve this problem. All those clear lenses were all chinese crap with phony DOT labels. They were sealed as well as a submarine with a screen door.
11-11-2014, 12:53 PM
Commercial Member
Preaching to the choir. I am already looking for other options.
11-11-2014, 07:44 PM
I put a strip of black electrical tape under the lens cover and over the raised edge of the lamp base to help form better seal. Worked like a charm.
2014 Sunseeker 3050S
Honda CRV (TOAD)
11-12-2014, 01:47 PM
Did you have the urge to strangle them?
If they are a "drain and dry" design why do they do neither? Then every year you also need to remove the lens and wash them (don't forget to dry them) as they fill up with dirt and further cloud the lens. What a crock. I know you need to be PC but I don't.
And it is great that you spend time here to help. Thank you!
11-12-2014, 01:50 PM
Commercial Member
You read my mind. I had 20 samples of tail lights in my office the day after I got their email.
11-12-2014, 01:59 PM
Average Joe
You can add mine to the list. I keep a supply of bulbs in the glove box....
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
