02-27-2021, 06:59 PM
Taking MH out of mothballs
Our last trip in the Forester was Nov 2019. I put in Stabil when I filled the tank after the trip. It has sat in our driveway since with 2 or 3 trips around our valley for about 20 miles each. I have run the generator religiously every month for 30-45 minutes every month or so with either the A/C on or the heat pump for a good load. Since the DW and I have just received our second dose of vaccine, we are planning trips and I want to get the MH back in shape. Last week, I cleaned the inside top to bottom, gave the tanks a good flushing and washed and waxed the outside. I have done some maintenance things like tire pressure, air bags, checked the air filter. I have oil and filter ready for the change. While washing and waxing, I checked the roof and it's good, as I applied Eternabond tape around the entire roof. I also reacquainted myself with all the components including slide outs, levelers, TV, Satellite and tested them for functionality and good working order.
Have I missed anything? What so I do about the gas in the tank being 15 months old, just use it up? I have a month until we head out.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
02-27-2021, 07:05 PM
I would drive around a little to burn it down and top it off with fresh gas.
Retired Navy
2016 Flagstaff 26 FKWS
It’s great that you’re able to get back out and use your RV.
If your house batteries require monitoring of electrolyte level, did you check them?
Opinions will vary about the old gasoline. I would just drive off and use it up. I have never had gasoline that wouldn’t burn.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
02-27-2021, 07:09 PM
I would just put some Sea Foam in the fuel tank, start it up and use it. Depending on how full your tank is, fill it the rest of the way up with premium fuel and enjoy!
2019 Forest River Berkshire XL40D
02-27-2021, 07:29 PM
I have BB lithium batteries, solar and just installed a 2000 watt inverter. Eager to get out there.
02-27-2021, 07:37 PM
Just looked at my tires with 14,000 miles on them. Michelins that are coming up on 6 years old. Look almost new and don't have the ozone cracks like those on the 03 Winnebago. Had to replace them every 30K at 4-5 years old. I know they recommend replacing RV tires after 6 years. Going to try to replace them end of the year maybe. At $2200, it's not an easy thing to do when they look like new.
02-28-2021, 08:21 AM
Kanadian Kamper
Sounds like my story and......
Everything sounds great......but the age of your tires is a topic of discussion, after all, you brought it up to start.
I know exactly where you come from trying to justify NOT changing them out just given their mileage and appearance. I had the same situation 5 years ago when I knew my tires were going to start their 7th year back in Canada, just as soon as I got home from wintering in Florida. Well......one tire, thankfully an outside rear, blew on the second day heading home. Roadside assistance did their work and we only lost 2 hours total.
Got home and immediately replaced all SIX with matching new RV specific tires.
Couldn’t even give the replacement tire away with only 1500 miles on it.
Ken and Terry
02-28-2021, 09:30 AM
I know, I will check the mfg dates this morning. I told a few a friend about 10 years ago that his 7 year old tires were not safe and they recommend replacing even with only 12K on them. He disagreed and 2 trips later on the way from LA to Yosemite on hwy 99 the inner right rear blew. His wife was following him with her car and phoned him, he felt it and thought it was just the rough road torn up by semi's. He called for road side service and the driver said he won't work on it on the hwy, So he drove off the hwy off ramp. He jacked the MH up took off the tire and was going to mount the spare which wasn't in the best of shape either. Turns out the spare's rim wasn't for the Ford chassis but Chevy and lug holes didn't line up. So he called for a tire to be delivered which took over an 1 1/2 hours it being on a Sunday. Then the new tire was mounted on the correct rim and the old spare put back under the MH. By the time they got on the road again they had lost almost 6 hours. They didn't get to their campsite until well after dark. He sold the MH a few months later.
So the purpose of this rant, was to convince myself to get new tires, ASAP depending on the date of course.
02-28-2021, 09:59 AM
If a tire “blows”, do we just assume it is from age? Do we know the pressure was correct on the day the tire failed? Do we know for sure there was no physical damage? I’m one of those guys that has many times run tires that were up to 14 years old, carefully monitored and successfully. The last time I had a tire blow was a long, long time ago on an old tire on a 1967 pop-up. From my experiences, I just have a lot trouble buying in to the tire age thing when they are just a few years old. Maybe a difference is that I store all vehicles indoors.
I apologize for continuing the tire topic, since it isn’t the main focus of this thread.
02-28-2021, 10:10 AM
Behindbars, not a problem. I just checked and can't find the Michelin LTX M/S2 in 16" anymore. They don't show it on the Michelin site I checked, Tiure rack or America's tire. Am I looking in the wrong places? Going to give America's tire store a few blocks away a call this morning. May have to go with Goodyear. I see Hankook tires on Ford vans but never on a MH. Plus they don't have a good reputation here .
02-28-2021, 10:16 AM
Hankook tires are the OEM tires on my 2019 chassis E-450 motorhome. They have been working well. I have also run the Dextero LT tires Walmart sold with total success. The only motorhome tire I ever had trouble with was a Michelin on my old MH. It got all twisted up and wore very unevenly.
02-28-2021, 12:10 PM
Michelin has replaced the LTX with the Agilis Crossclimate. The Agilis comes in two versions, load range E and C-metric. Specs for the load range E is identical to the LTX and the tread pattern looks the same. The C-metric is very different in that the tread is directional and the load range is 20% greater.
I purchased the C-metirc version because my 2861DS rear axle runs at 9600 lbs loaded for travel. The load range E max is 9880 lbs at 80 psi, while the C-metric is 11900 lbs at 80 psi. The C-metric gives me much more margin especially since I know the axle weight is not balanced side to side, the left is more than half and likely exceeds the load range E max.
The other advantage is that I can run the tires at lower pressure for my axle weights, instead of 80 rear/75 front, I now run 70 rear/65 front. I am just completing a 2000 mile trip that I take each winter and I can say that I have noticed that the road surface roughness is softened, still there but not as hard feeling. My wife just shrugs, but she is not tuned to the driving performance of the RV. I also feel that the steering is more centered possibly due to lower pressure and wider tread. I am very happy with this tire.
Some may be concerned that you can't rotate the directional tread tires, but I have never rotated my class C tires because they time out before wearing out.
This link shows the load/inflation differences for the two versions.
https://www.rvsafety.com/images/pdf/...ionrvtruck.pdf
2017 Forester 2861DS
towing 2015 Jeep Rubicon
02-28-2021, 12:26 PM
Certified Curmudgeon
Alternative Maybe
No direct experience or reviews on this option. Just throwing it out there:
https://youtu.be/GRv0IIAv6j8
Mike Dropped
02-28-2021, 12:37 PM
My spare has never been touched and is an off brand tire not a Michelin. So I will probably use one tire that I replaced in Feb of 2018 and make it my spare and have a new tire put on the spare rim. Hope the spare rim is same as the 6 others. Look what happened to my friend on the earlier post #8.
02-28-2021, 12:40 PM
Originally Posted by Duckogram
Yes, another example of the C-metric (commercial) option. He does a good job explaining the difference and confirming what you can find in the load inflation tables.
02-28-2021, 02:49 PM
10 years
Per other reports on this forum, Michelin claims their tires are good for ten years.
Larry
02-28-2021, 03:20 PM
That's what I read. But I have recently found ozone cracks starting. Tire dealers say 6 years. Of course they would.
02-28-2021, 07:01 PM
My Forester came with Hankook tires on it and I have had no complaints to date. The spare tire is some no-name China bomb that I am planning to replace with a Hankook. One item that caught my attention was in Post #8 about the spare tire rim having a different bolt pattern than the wheels on the motorhome. I guess if I have a new spare installed, that will be a good time to check the bolt pattern on the rim.
2020 F.R. Forester 3011DS (2018 E-450 Chassis) (32')
Toad:2018 Wrangler Rubicon Unlimited
2011 Keystone Montana 3455SA (38') with F350 diesel
2004 ALFA Leisure Gold Diesel Pusher (41')
1990 Elite (27' C Class, not on rental fleet)
1984 Elite (25' C Class on GO Vacations rental fleet)
02-28-2021, 07:38 PM
Hydrog and KenandTerry, I see you both are around Toronto. The DW and I went on a Princess Cruise back in the fall of 2019 with a land tour starting in Toronto, over to Niagara for the day then 7 day bus tour all the way up to Quebec to meet the cruise ship. Then another 10 days onboard. I must say you have a beautiful country with very nice people. We especially like a boat cruise thru the Thousand Islands. We hope to one day take the MH up there once the border opens up.
Hydrog, I heard complaints about the Hankook tires and then Ford started putting them on the vans and trucks. I think most of the complaints were about trailer tires.
They are $60 less each than Michelins. That's over $360 plus tax.
02-28-2021, 07:47 PM
Kanadian Kamper
Glad you enjoyed your trip, and if things improve for all, and I mean all of us, we’d love to have you up this way again. We’ve camped in the Niagara region several times, so we know the area well.
My wife Terry and I hosted the largest Canadian FROG Rallies in 2017 and 2018 with boat tours around the Thousand Islands as one of the events during our rally. Both years, we had a large attendance by a number of American FROGS from a number of states joining up for 4 days of fun with our Canadian FROGS.
If I say so myself......I’m pretty sure a good time was had by all.
We’ve attended a number of other FROG rallies ourselves, obviously a number of them in the states. We’ve always had great times. With FROGS, there are no boundaries.
When COVID allows, we have a guest spot for you up here.
FROG ON!
Ken and Terry
