08-12-2020, 12:20 PM
Tire pressure gauge for inner dually on sprinter body
Hello
I have a Forest River forester MBS and have tried 3 different tire pressure gauges to check the pressure on the inner dually. I can reach and unscrew the cap no problem but even with a right angle adapter and gauges meant for dualies, I can’t get the gauge onto the valve. I did read that you possibly have to take the hubcap off to do it which just seems crazy. I also read that I should get valve extenders but also read a lot of bad things about them and causing flats. Any help is appreciated.
Rachel
08-12-2020, 12:41 PM
Originally Posted by rachelr
Hello
Rachel
I screw on an extender to check and/or add air then remove it when finished.
Kim
08-12-2020, 02:00 PM
valve extension
X2 "I screw on an extender to check and/or add air then remove it when finished"
I have an assortment of extenders that have accumlated over the years and usually use two or three each time I check the pressure. Knock on wood - the tires are holding very good, haven't had to add for the last couple trips.
08-12-2020, 03:19 PM
Commercial Member
rachelr
will you send me a private message with the last 6 of your vin and contact information. I would like to see when your unit was built.
Kary Katzenberger
Product Manager
Forest River Class C Division
08-12-2020, 04:10 PM
Certified Curmudgeon
Hello
Rachel
I agree with your opine on valve extenders and it is a pita to have to take the wheel simulators off (mine are hammer-on). Since you can get air in the inners then you can put a gauge on that tool as I have on the attached photo. So now I can get the proper pressure in. However that leaves the issue of checking the pressure. Every time you put a gauge on the valve stem you lose air. Putting an extension on creates a double loss. My solution is to use a TPMS as my valve cap.
I check my tires using the tire minder app on my smart phone. Only the inners would require simulator removal to air up. Last year was a short adventure. Only went up to Kennybunk, ME then over to Watkins Glen, NY and back. 7000 miles and no air loss. YMMV
Mike Dropped
08-12-2020, 05:12 PM
Thank you so much for these suggestions! I just ordered a TPMS system and valve extenders just to put on if I need to add air.
I really appreciate it!
08-12-2020, 05:26 PM
Originally Posted by karykatz
rachelr
Kary,
Since some of us have the same issue as racheir , what is the reason behind knowing when a unit is built?
Kim
08-13-2020, 08:36 AM
The problem with permanently installing extenders is they might cause a vibration, leading o failure. There’s a fix for that. I’ve installed these units on my Forester and on two different Ram duallys. They work...over 200,000 miles without a failure.
https://www.shinyrv.com/product-cate...edes-sprinter/
BIRDS AREN’T REAL
08-13-2020, 08:40 AM
Commercial Member
We install valve extenders on the MBS product at the factory. I'm trying to determine when the unit was built so I can review why the unit might not have the extenders.
Kary Katzenberger
Product Manager
08-13-2020, 11:36 AM
Emm-dee,
My 2020 MBS came with those ones already installed. I still have to pop the hub cover off to check properly.... maybe they used too short of ones?
Brian
08-13-2020, 02:07 PM
Originally Posted by papagyo
Emm-dee,
Brian
If the rubber type inserts are installed they will lock the stems in place. I had to put very small, maybe one inch, extensions on all the wheels on my Forester so I could install the TST sensors.
BIRDS AREN’T REAL
08-13-2020, 03:27 PM
I have brass extenders on all wheels on my 2016 Forester and use a TPMS on them all and haven't had any leak problems. That doesn't mean it doesn't happen, but I know many people, besides me, who use them successfully.
08-13-2020, 09:11 PM
X2 Installed these earlier this summer.
Bill
2015 Coachmen Leprechaun QB220 (purchased 4/2018)
08-15-2020, 02:34 PM
Ours was built in 2015 no extenders,pain in da butt!!
08-16-2020, 09:55 AM
Can you mail the extenders to us?
