09-26-2021, 10:12 PM
Tow haul not working
Does anyone know if there is a fuse for the tow haul? We are having electrical problems with the cab. First the instrument panel lights quit working, and yes, I have tried the rotating wheel dimmer switch a hundred times. Checked the fuses inside and they are all good. Checked two fuses under the hood labeled “cluster” and they are ok. Now the tow haul is not lighting up or engaging which is a real problem driving in the mountains where we live.
We have a 2018 3011 ds Forester. Would appreciate any suggestions.
09-27-2021, 02:55 AM
Camping the Natural State
In the meantime, isn't there a way to shift down ?
2021 Rockwood Ultra Lite 2614 BS
09-27-2021, 10:01 AM
I assume your 3011 is a Ford E-450. I don't know if you have the 5 or the 6 speed transmission. If the 6, for sure you can shift down by moving the lever to 4, or to 2.
09-27-2021, 01:55 PM
Kanadian Kamper
The 5 speed showed 3 2 1.
Ken and Terry
09-27-2021, 08:36 PM
Now a "Top Member"
Electrical gremlins are the toughest ones. It sounds like you're on the road, but is there still some warranty on it. It may take a dealer to pinpoint this one. Good luck.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
09-27-2021, 09:01 PM
Certified Curmudgeon
Transmission
Just FYI - According to Ford Fleet literature the 2016 MY was the last year for the 5 speed in the E Series 6.8L units.
Mike Dropped
09-28-2021, 03:44 PM
Just for giggles, disconnect the negative battery cable from the battery.. and wait a minute and reconnect.. It sometimes fixes a lot of problems..
Clint...
2015 F350 4x4 gasser.. 2017 Rockwood 2506S TT
Ardenvoir, Washington (near Wenatchee)
09-28-2021, 04:03 PM
Your chassis manual should give you a fuse breakdown.
2016 Salem 27RKSS
09-28-2021, 06:50 PM
cdog7201
tow haul not working
make sure the light bulbs in the circuit board in the dash are good by taking out and checking them I had this happen to me and had to replace the light bulbs but if your sure the tow haul mode is not working it is probably a fuse but try unhooking the negative battery post and leave it off for about five min and then hook it back up .some times this will reset the computer. good luck
10-03-2021, 10:22 PM
I found the problem. The fuse labeled transmission under the hood was missing. When I was checking them all to see why the instrument lights weren’t working I must have put that one back in a blank space. There was no fuse in that space. I put in a new fuse and tow haul is now working. Still don’t have dash lights but will worry about that another day.
10-04-2021, 09:01 PM
Now a "Top Member"
Good job, and thanks for posting up the fix. Hopefully you can now get the dash lights going now.
Ed and Sharon
2010 Wildcat 28RKBS
Retired AF MSgt
