07-06-2015, 06:57 PM
#21
on 05 gm dura max using tow haul locks up the converter which runns the trans cooler ,i dont know about increasing the voltage to the TT, but i will check it out.
07-06-2015, 07:48 PM
#22
Originally Posted by gmacklem
When I was towing my travel trailer with my F-150, I turned overdrive off. But now with the Sunseeker, I am getting ready to tow a Honda CRV. Should I have tow/haul mode on or off for towing with a class C?
Thanks.
Greg
On! It's what it was designed for.
07-06-2015, 09:11 PM
#23
Happy Keystone Owner
Originally Posted by Stovebolt
They have a tow/haul on there for a reason. With today's computer driven vehicles, the dealer can tell if you towed with out it on and let's say you burn up a trans, it's on you if they can prove it and want to prove it. I use it because it was made to use when you are towing or hauling heavy loads. I've seen a lot of remarks over the years about the tow/haul mode, I don't understand why you wouldn't want to use it. Saving a gallon of gas (if it saves any at all) versus a new trans, I'll pay for the gas.
Yep, same here. My truck logs all miles connected to a trailer...tow/haul better had been activated.
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2020-37 2019-36, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....55
07-06-2015, 09:40 PM
#24
I have a 2015 GMC Sierra 1500. First, i have never heard of "Increased Transmission Fluid to the Cooler". I am not saying it isn't true, just saying i never heard of it. I DID read in the OWNERS MANUAL, that shifting to Tow Mode does increase the power output from the alternator. But more importantly i think i read that when the COMPUTER/STABILITRAC realizes that there is a trailer with another set of brakes, it utilizes this as another safety feature to keep control of a vehicle under emergency circumstances. I do not know if this happens only when in Tow Mode, or if it happens simply when a trailer is plugged in, but it is something to consider.
db
07-06-2015, 10:10 PM
#25
Also tow hual mode increases your blinkers from 3 times to 6 times on later models when you use the lane change feature.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
07-07-2015, 08:17 AM
#26
TURBS
2011 32bhok Sabre
Shudda read my owner's manual. I wondered why it was 3 sometimes and 6 at other times. Thanks.
Sent (I think)
07-07-2015, 08:21 AM
#27
Sent (I think)
Regardless what oc says, sometimes I know what I'm talking about. [emoji12]
TURBS
2011 32bhok Sabre
07-07-2015, 08:32 AM
#28
Regardless what oc says, sometimes I know what I'm talking about. TURBS
Only on very rare occasions.
07-07-2015, 09:28 AM
#29
One thing I've learned from the many tow/haul threads on this forum (and others) is that readers should NOT accept as gospel all the general comments made about T/H functions. Although these are on the internet, they are not across the board true. One might write "T/H causes ________" and it might on their vehicle but it doesn't on others. T/H is not created equally across all years nor across all lines. I've read "T/H locks out overdrive (or high gear)", but it doesn't on mine. In T/H mode, my truck will tow my trailer in 6th (high) gear (my two top gears are overdrive) AND in 4 cylinder mode.
Word to the wise: when you read something here about tow/haul mode, don't automatically believe it. Check with your owner's manual (or with Turbs - or is it Turns?) about the T/H function of your specific vehicle.
07-07-2015, 09:41 AM
#30
If it has (T/H) use it if you are (Towing or Hauling) it is REAL NICE going (Down Steep Grades) also! Youroo!!
07-07-2015, 09:46 AM
#31
Yes, but even that feature didn't exist on my last truck.
07-07-2015, 10:08 AM
#32
#33
I use tow/haul all the time. There is no significant difference in millage difference between the two. Set it and leave it.
07-07-2015, 06:13 PM
#34
One added bit on the E-450 with a 2010 & newer (maybe 2009) Torqueshift. I've been told using tow/haul makes the tranny start off in 1st gear, normal mode you are starting off in 2nd. If you count the shifts while accelerating you will feel a extra one in tow/haul mode.
2011 Sunseeker 3170DS - 30,000 miles explored
07-07-2015, 07:57 PM
#35
Our 2010 E450 uses all 5 gears in normal and in tow/haul.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
07-09-2015, 08:54 AM
#36
I find the tow/haul on my 2015 Tahoe work much better than it did on my 2004 Tahoe. I tow my Surveyor 264 in 5th most of the trip I am currently on. While a fairly flat trip except for the hills in southern Missouri I was able to run with the cruse control on. I could nto do this with the 2004 Tahoe and same trailer.
07-09-2015, 09:19 AM
#37
(Dry Huunday)
I use T/H all the time when towing the camper....just wish I used it more often!!!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
