Old 08-04-2020, 04:25 PM   #1
Towing trailer
I have a 2019 Sunseeker 3050s and I was thinking about pulling my 10 x 5 utility trailer with my golf cart on it . Do any of ya'll think that would be a problem? I have added Roadmaster sway bars it handles really good.
clover rv is offline   Reply With Quote
Old 08-04-2020, 04:43 PM   #2
Ambassador Member
Duckogram's Avatar
Towing is mostly about weight. You have weight rating on your hitch that should be 7500 lbs. Then you have Combined weight which is loaded RV and loaded trailer. Then you have your trailer GVWR and finally there is your tongue weight.
All of those numbers are available only to you.
Got Brakes?
Ducky
Ď18 Sunseeker 2800QS
Towing Smart
No PMís.
Old 08-04-2020, 07:43 PM   #3
To answer the question you would need to tell us how much your loaded trailer weighs. We could hunt down the tow capacity of the RV, but not the weight of your trailer. You also need to consider the need for trailer brakes. Brakes are always good, but if the trailer is 3000 pounds or more, you are definitely going to need them. The Sunseeker E450 has a socket to add a brake controller, but you will need to supply the controller.
2020 Sunseeker 2440DS Ford, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 08-04-2020, 10:15 PM   #4
Towing trailer
Ah no !! to the extra info. A 10 x15 utility trailer with a golf cart behind an rv this truly might be a great example of you wonít even know itís there. Honestly you shouldnít have any problems.
moose074 is online now   Reply With Quote
Old 08-18-2020, 09:40 PM   #5
Bezzola's Avatar
I pull a enclosed with my 3011ds with 2 atv and 100L of spare fuel and waterClick image for larger version
Bezzola is offline   Reply With Quote
Old 08-18-2020, 09:52 PM   #6
900lbs for the golf cart, 500 for the trailer.
Won't even see it in the mirrors going straight. Brakes are not needed on a trailer most states until you hit 3000lbs
2019 F150 4X4 7050 GVWR 1903 payload
2018 Avenger 21RBS 7700 GVWR
Mike134 is offline   Reply With Quote
Old 08-19-2020, 10:46 AM   #7
a71rambler is offline   Reply With Quote
towing, trailer
