Old 03-19-2018, 09:25 PM   #1
Transmission Temperature
I have a 2017 Forester on e450 chassis and worry about my transmission tempature. Cause I know when Im pulling with my truck the transmission temp. Is what I need to worry about compared to engine temp. So is there an aftermarket gauge to see the transmission temp? I was looking at scan gauge but it looks like they only have a water temp reading.
Calvinbell3 is offline   Reply With Quote
Old 03-19-2018, 09:50 PM   #2
llr
I would look at forscan and a compatible odbii adapter. On my 2009 f150 it had transmission tempature so I would guess it would on yours.
TT 2021 Grand Design 2800BH
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
prior TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 03-19-2018, 10:30 PM   #3
Tombsy's Avatar
I have a Scangauge in my E-450, you have to try a few custom codes for tranny temp to find the correct one but it wasnt hard and mines working great. I did the coin tray mod and installed it in the dash.
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 03-19-2018, 10:43 PM   #4
Thanks for the response guys! Do you have pictures of this cause Id love to get rid of that dumb coin tray
Old 03-19-2018, 11:23 PM   #5
Bilcin's Avatar
I have this and it simply plugs in to your obdi port, download an app on your phone and you van see real-time temps of engine oil, transmission temp, coolant temp and so much more. Simple plug and play. Click image for larger version
Only about $22 for the devise and 4.95 for the Tourgpro app.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 03-20-2018, 06:34 AM   #6
Gumpster808's Avatar
Another scan gauge user here. Worked great all last year.
I did the command strip Velcro (plastic and not cloth kind). Put on top of dash above steering wheel so I could glance at it easily going down the road.
2014 3051S - First RV for us
2022 DX3 RB on order
Gumpster808 is offline   Reply With Quote
Old 03-20-2018, 08:03 AM   #7
Tombsy's Avatar
It takes some work with a dremel to open it up a bit for the scangauge but it fits nicely when done.Click image for larger version
Brian
Old 03-20-2018, 09:36 PM   #8
Thanks everyone I just pulled the trigger on a scan gauge thanks for all the responses
