Old 07-07-2013, 09:29 PM   #1
Trim piece above cab doors
See attached pic. This trim piece constantly comes out. I have pushed it back in the channel many times. It comes back out the next time I hit the road. Does anyone know if it aesthetic or functional (I.e., keeps water out)? I can live with it if its for looks but don't want water to be getting in.
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 07-07-2013, 09:41 PM   #2
It is pulled too tight, it needs to be slid either up or down which no doubt will leave a gap. You might be able to find some more at the rv dealer and cut a longer pc.
Old 07-08-2013, 01:47 PM   #3
Motorized GM
Just aesthetic to cover the screw heads.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 07-08-2013, 07:15 PM   #4
Sonething different, but why is there no cab to wall gasket on yours? I know this wasn't what you were taking a picture of but I noticed yours is different then mine.
mwebber78 is offline   Reply With Quote
Old 07-08-2013, 07:34 PM   #5
No idea. Is there supposed to be one? I recall you had a forester. This is a Sunseeker. Maybe that's only on the forester perhaps. Anyone with a Sunseeker have one?
Old 07-09-2013, 07:00 AM   #6
i have the cab to wall gasket on my 2011 sunseeker . i also had the same problem as you with the trim coming out seemed worst on windy days i filled the bottom void with caulk to stop the air flow under it so far 3 trips and 1000 miles later it has not came out again
lbrunning is offline   Reply With Quote
Old 07-09-2013, 08:18 AM   #7
Motorized GM
We switched the design of that cab transition. We started using an automotive D-seal so we had a cleaner look on the outside.
Old 07-09-2013, 07:41 PM   #8
bclemens -
Not to keep at this but...
The first picture below is mine. I don't see a seal. Are you saying there is a redesigned hidden seal (for a cleaner look).
The second pic below is from my local Sunseeker dealer today. 2 of the 3 units on their lot had this seal. The other unit had nothing like mine.
Just want to make sure mine has a seal of some sort even if its hidden.
Old 07-09-2013, 07:57 PM   #9
That's the type if seal I was speaking off, all the Foresters and Sunseekers I've seen have that type of seal. I prefer that seal as its visible, easy to inspect, and easy to verify as intact, JMHO.
Old 07-09-2013, 08:02 PM   #10
Plain Old Member
My '13 has the more hidden d-seal. Forester and sunseeker identical in that aspect, at least what I saw at the factory a few months back. I can assure you, either way its done its sealed. Brian may can shed more light on it. That trim piece coming loose on yours can be bought at most any RV place or at camping world. Can't remember proper name for it. Over time, they can draw up a little. Same trim cover you see on tons of towables. I'd just pull it out and replace with new. Very cheap for a whole role.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 07-09-2013, 09:58 PM   #11
2012 Solera
I believe the trim piece shrinks. As it is fastened at the ends, it pulls out of the corner to compensate for its shrunken shorter length. I released one of the ends (took the screw out), re-inserted the trim into the corner and pushed the trim material towards the corner (to ensure some extra length). I then re-fastened the end. Stayed in place after that.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-10-2013, 08:00 AM   #12
Motorized GM
John is correct. Instead of a vinyl seal on the outside, we use an automotive rubber seal in between the wall and the chassis.
