Old 07-24-2013, 09:56 AM   #1
tv antenna booster - where is it?
Is there a TV antenna booster in 3050S? Had lousy TV reception in MH. Same campground in the old RV got more stations. Hopefully there is one somewhere in the RV.
johnlantz is offline   Reply With Quote
Old 07-24-2013, 10:23 AM   #2
I had my 3051S antenna changed to the Wineguard model with the built in booster before taking delivery.
Tim
2013 Forester #3051SF
2009 Toyoda Tacoma (toad)
2010 Newmar Dutchstar (Sold)
2011 Fleetwood Bounder (Sold)
trwmodela is offline   Reply With Quote
Old 07-24-2013, 12:15 PM   #3
If its like the 2690, it is on the switch plate where the ant coax from the TV plugs into the wall, its a little push button switch.
Geri is offline   Reply With Quote
Old 07-24-2013, 02:24 PM   #4
There is only one even if you have multiple TVs. It's usually on the front or main TV connection box. Little button with a green light.
ATVer is offline   Reply With Quote
Old 07-24-2013, 02:27 PM   #5
Right. You should se a little green LED light on when the booster is on. I just changed my Winegard wingman out and put on a JACK antenna, very easy to swap out, and it works much better, so far. Randy
Old 07-26-2013, 07:26 AM   #6
Yep - I had a little green light along with a button on my old motor home. Went over last night searched everywhere in the RV and could not find any booster switch or button.
Old 07-26-2013, 07:29 AM   #7
Herk7769's Avatar
It is there somewhere. It is also the switch for controlling whether you use the park cable or roof antenna.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 07-26-2013, 05:57 PM   #8
DangerCliff's Avatar
Same way with my 2013 , 2860 can not find a booster switch anywhere. Don,t know how I would make out if I ever hooked up to cable, any help would be appreciated.
2013 Sunseeker 2860 Chevy
2014 Chevy Spark
Days Camped 2013 93.
Days Camped 2014. 89
DangerCliff is offline   Reply With Quote
Old 07-26-2013, 07:26 PM   #9
Don't you have a input selector/ switch box somewhere in a cabinet? If so press "cable" button on the front of the switch box for the correct TV you be viewing from.
4Gcampers is offline   Reply With Quote
Old 07-26-2013, 07:43 PM   #10
got it , so that would do the cable and the booster must be on all the time as there is no switch. Thanks for the help
2014 Chevy Spark
Old 07-26-2013, 08:09 PM   #11
Yes, it has a 12v feed to the back of it. It's made by magnadyne if its the same as mine. Always has power to it. Just punch the button for cable/ ant/ DVD. Like you, I searched for a "boost" button on near the power outlet like my older travel trailer.
Old 07-26-2013, 08:38 PM   #12
wesslvm's Avatar
Same setup on my new 3050S, I had the same question before. I couldn't get TV over air in ME either, but it works locally.
Wes
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 07-29-2013, 05:56 AM   #13
I do see some wires (not coax cable) going into the back of the box that has all of the switches (eg. antenna, dvd, etc..). I'll take a pictue when I get a chance. If I understand what folks are saying it's hard wired to be "always on" when I select the antenna option?
Old 07-29-2013, 06:31 AM   #14
Herk7769's Avatar
If your Sunseeker does not have a Winegard roof antenna system, you will need to let us know what type of antenna you do have so we can get the manual for you. That should tell us what you need to be looking for.
Old 07-29-2013, 08:40 PM   #15
Yes it's a winegaurd. I'll try the suggestions when I get back to the RV this weekend.
Old 07-29-2013, 08:46 PM   #16
B and B's Avatar
I took out the stereo in my 8289WS and replaced the 3 out 7.5 db loss per port splitter with a 3 db loss 2 way splitter to feed the bedroom and the living room. I hooked up the tailgating connection in the bay to the output of my living room sat receiver.
Do this increased my digital signal strength by 3 bars on the same station.
Brian
B and B
Old 07-30-2013, 06:34 AM   #17
The last post thoroughly confused me. My wife won't be happy when I have to tell her I'm taking apart things already on the new RV.
All I'm trying to do is watch the same TV stations I could get on my 8-year old RV with my brand new RV... didn't think it would be that hard.
Old 07-30-2013, 06:47 AM   #18
Herk7769's Avatar
You should not have to take anything apart. FINDING the signal selection panel is that hard part as it is floorplan dependent.
Look For:
ID:	36514   Click image for larger version
Name:	Sandpiper Cable connections Bedroom.jpg
ID:	36515   Click image for larger version
Old 07-30-2013, 08:04 AM   #19
B and B's Avatar
Look For:
But if you remove the splitter you get more gain=more channels=more choice in rural areas. In Canada we have areas in populous Southern Ontario you can not get digital tv at all and maybe one noisy analogue channel.
Just a comment that less in the signal path means more channels.
B
B and B
Old 07-30-2013, 08:19 AM   #20
Herk7769's Avatar
B
B,
While not helpful to the original poster, I will put my comment to your post. The "signal loss" in a single digital quality splitter is quite small and the range increase would be measured in yards (not enough to make a significant difference in transmission tower reception). IMO
