Old 03-07-2017, 03:23 PM   #1
TV mount
I want to mount a tv on the bedroom wall of my 2003 sunseeker le2600, there's a coax attachment there and a power outlet but no shelf or other means of supporting the tv. On the other side of the wall is the bathroom shower, can I use a molly bolt type of fastener, and will this wall support a tv, I'm looking at a 27" flat screen about 4lbs?
Indianaduo is offline   Reply With Quote
Old 03-09-2017, 04:07 PM   #2
If there is coax and power, likely there is a mounting pad built into the wall for a wall-mount. You can use a common stud finder to locate it, or simply tapping on the wall will work as well.
Another option would be to find other units of your model with a wall-mounted TV.
Help that hopes!
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
mount, tv mount
