Old 11-16-2017, 12:30 AM   #1
twochicksandarv's Avatar
Type of battery and access
Can someone please tell me what type of batteries (sealed, gel, or flooded) come in the 2015 3010DS and if they can be accessed from underneath the RV or just through the stairwell? Iím thinking about getting portable solar and need to know if I can attach the cables underneath.
twochicksandarv is offline   Reply With Quote
Old 11-16-2017, 12:33 AM   #2
sgtlm17's Avatar
They are flooded and accessed from steps. However there is a hole in the box that leads underneath for wires so you can certainly run solar wires into the box from underneath the coach.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 11-16-2017, 01:00 AM   #3
Thank you.
Old 11-16-2017, 10:35 AM   #4
Senior Members
Butch & Lena's Avatar
What does it mean by a "flooded" battery?
2015 3010DS Sunseeker
2010 Jeep Wrangler Unlimited
Butch & Lena is offline   Reply With Quote
Old 11-16-2017, 10:37 AM   #5
Iwannacamp's Avatar
Wet cell/lead acid type battery
2017 Puma 297RLSS
Old 11-16-2017, 10:38 AM   #6
marinerjoe's Avatar
A conventional lead-acid battery. As opposed to AGM (absorbed glass matting) and gell cell. Some have (easily) removable caps to check water levels and add water. Others have a cap that covers three cells each and it looks like a maintenace free battery. Those can also be removed to check and add water.
They are usually if not always the least expensive option, and usually have the shortest useful life. I've seen 3 - 5 years on my boat (with 8D flooded batteries). Remember, only use DISTELLED water to top them up.
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
marinerjoe is offline   Reply With Quote
Old 11-16-2017, 10:40 AM   #7
Senior Members
Thanks for the info, much appreciated!
Old 11-17-2017, 03:40 PM   #8
Senior Members
Where do you think the caps are on the batteries in this picture.Click image for larger version
Old 11-17-2017, 04:03 PM   #9
sgtlm17's Avatar
The caps are the pieces with the white lettering
2011 Jeep JK Toad
Old 11-18-2017, 08:42 AM   #10
Be sure to check the water level monthly. If you keep your rv plugged in they will occasionally recharge. I had one battery go dry in one cell so the charger kept charging that battery. Ended up replacing both batteries for $170.00. Now I have a spare battery. I check them often and top off the cells with distilled water when needed.
2017 Sunseeker GTS 2800 QS
2017 Jeep Grand Cherokee toad
1987 Sunstream (sold)
Retired BTC USN
Chesapeake, Virginia
charles l is offline   Reply With Quote
Old 11-18-2017, 11:45 AM   #11
Sagecoachdriver's Avatar
Originally Posted by twochicksandarv View Post
Can someone please tell me what type of batteries (sealed, gel, or flooded) come in the 2015 3010DS and if they can be accessed from underneath the RV or just through the stairwell? I’m thinking about getting portable solar and need to know if I can attach the cables underneath.
I have a (PORTABLE) Renogy solar suitcase 100 watt and originally used the alligator clips to attach to the battery. I then purchased some Anderson connectors that matched the connectors on the suitcase and mounted one on the outside near the rear fender well. It was easy to wire it directly to the house batteries a foot away via the vent holes in the battery case. Note there is a 12v negative ground buss bar directly behind the steps and the negative from the portable polar can be attached there. Make sure that you add a fuse to the connection going from the solar to the batteries like the one in the bottom photo with the alligator clips.
I have gone on to add 200 watts of solar panels to my roof and added a cut-off switch allowing me to select either no solar, roof top, suitcase or both roof top and suitcase. All are fused. You will quickly find that the suitcase or portable is not sufficient to charge the house batteries adequately. I have found that my 200 watts on the roof isn't cutting it especially in the fall and winter with lower sun.
To be more specific, my 100 watt portable has a max of 5.2 amps and when out dry camping the draw from the fridge and every other parasitic drain draws 1.3 amps. Therefore the best I can get is about 3.9 amps per hour to recharge the batteries.
ID:	156650   Click image for larger version
ID:	156651   Click image for larger version
ID:	156652   Click image for larger version
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
Sagecoachdriver is offline   Reply With Quote
Old 11-23-2017, 01:37 PM   #12
Thanks. We purchased the renogy suitcase, so the info and photos are very helpful.
Old 11-23-2017, 02:12 PM   #13
Are you going to use the alligator clips or go for a more permanent attachment?
You can buy a 2 Pin Quick Disconnect Wire Harness SAE Connector Bullet Lead Cable (12 AWG) and attach wires directly to the battery terminals and run it thru the battery compartment vent attaching it in an accessible spot between the steps and rear wheel. Leaving the connector exposed for easy connecting of the panels. Some come with optional dust cap.
Also, I was at Renogy a week ago and saw that they upgraded their controller on the Solar Suitcase from the ViewStar 10amp to the Adventurer 30amp. That's great if you ever decide to expand! I had to buy the Adventurer 30amp when I added my roof top panels.
Old 11-23-2017, 03:36 PM   #14
We like the permanent attachment. It seems convenient and has clean look. Thanks!
Old 11-23-2017, 04:24 PM   #15
TwochicksandaRV, don't forget to add a fuse like the one on the alligator clip pigtail.
battery
