05-30-2016, 04:48 PM
Upgrade ac thermostat 3010ds
Wondering if anybody out there has upgraded their AC thermostat, from the stock. I want to upgrade it to one that will actually turn the air conditioner off once the RV reaches the temperature I want just like the one in my house
05-30-2016, 04:59 PM
Chief tinkerer
Thermostat
Hello. I don't know if this applies, but on our 3010, we just discovered that with the stock T/stat, the AC fan control is selectable to Au (auto), Lo or Hi. Accessed by cycling through until "fan" is highlighted and then either up or down to select. In Au, the fan shuts off when the AC does.
Gary
 2017 SunSeeker 3010DS
05-31-2016, 06:51 PM
DW's 401(k) Plan
Hmmm.... saw the "Lo" setting when we had the fan on and never thought to explore any further.
No offense, but, I'd be more impressed if someone came up with a good t/stat that didn't have the huge range when you had it on HEAT. Seems the one in my unit kicks off and then it cools down at least 5-7 degrees before the heat kicks back on. I can deal with the fan still running when the a/c hits the proper temp. But, those cool swings...... hard on the old man!
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
06-01-2016, 06:29 AM
Just installed a Honeywell in our 5th wheel and took out the Dometic that was there...it is really close to about 1 degree for heat and cooling.
06-01-2016, 09:52 AM
2012 Solera
[QUOTE=I can deal with the fan still running when the a/c hits the proper temp. But, those cool swings...... hard on the old man!  [/QUOTE]
Dometic temp swing is adjustable. See page 7 :
http://www.dometic.com/QBankFiles3/E...nual_17590.pdf
FYI
JLeising
2012 Solera "S"
Calif SF Bay Area
06-01-2016, 05:14 PM
Thermostat replacment
I replaced the thermostat with a digital and couldn't believe the diff in temp control. Just like home. Many thread on Facebook how to do it.
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
Days camped 2018 136
06-01-2016, 05:40 PM
Old Camping Squid
X2. I install the Honeywell Digital and the heat / AC stays within 1 degree.
The old slider unit, the wire hookup for new thermostat ( you don't use two old wires if you don't want the two speed fan option ) and new digital unit.
Larry Collins { PM }
2006 F150 Supercab 5.4 Flex Fuel
2017 H-D FLHTK Ultra Limited
EZgo TXT and ClubCar Precedent golf carts
2009 Forest River Salem 30QBSS
U.S. Navy Veteran
06-01-2016, 06:01 PM
Old Camping Squid
Just in case you can't see the details in the picture, ( this is my 2009 Forest River Salem 30QBSS, I do not know if your unit color code is the same as mine. ) On my QBSS the old thermostat had:
+7.5 = RED
Cool = Yellow
Furnace = White
High Fan = Blue
Low Fan = Brown
Ground = Green
Wires to Digital are:
B and O are only used for heat pumps. I did not use...
G = Brown for low speed fan
Y = yellow for AC unit
W = White for Furnace
R/RC is jumped together and stay that way it is for the GROUND Green wire.
The Camper has two wires not needed ( unless you want the two speed fan, in that case you will use the Blue wire ) The RED +7.5V is not needed or used at all. Blue wire or Brown wire needs to be hooked up for fan speed. I only used the low speed and hooked up only low speed.
I have used this Thermostat all year, summer and winter, it works for me and stays within one degree.
I hope this will help you and I hope your wire color code is the same. It's a real pain in the butt to figure it out if nothing matches. My Yellow and White wires are the only standard wire colors. Took my a long time to figure it out. Good Luck.
U.S. Navy Veteran
06-01-2016, 07:11 PM
DW's 401(k) Plan
Originally Posted by JLeising
I thank you!
But, if my t/stat only has a 2 degree differential (at most), I must have p-$$ for blood! However, I will change it to a 1 degree differential.
06-01-2016, 07:16 PM
DW's 401(k) Plan
Sorry, Sarge, I don't do FaceBook. Which t/stat did you replace yours with?
06-01-2016, 08:19 PM
2012 Solera
Originally Posted by DaGrinch
I thank you!
Believe it is +/- 2 degrees (4 degree swing) or +/- 1 degree (2 degree swing). Also I understand this thermostat communicates digitally with a control module in the AC housing that controls both the furnace and the AC (and the heat pump if so equipped). No a simple replacement as I understand.
JLeising
2012 Solera "S"
Calif SF Bay Area
06-01-2016, 08:29 PM
DW's 401(k) Plan
Been out of school too long - forgot +/- 1 and +/- 2 would be 2 & 4 degree swings respectively. That would make sense since my interior independent thermometer shows the fairly large swing of about 5 degrees.
Now, hopefully, I won't need the furnace until later in the year. But, I'll still check it. Also, this is the first time I've had to deal with the heat pump on the a/c. A little different.
06-02-2016, 11:11 AM
What Honeywell stat did you use? Last year I replaced my Dometic analog stat with a Honeywell digital. After a week of cussing and not being able to make it work I called Honeywell and they told me I couldn't use the stat I had as a replacement. Don't ask what model I had, it is in a landfill somewhere.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
06-02-2016, 05:38 PM
I have my Dometic digital thermostat set To +-1 and it is a world of difference from the +-2 setting.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
