The short answer is no.
Here is everything you wanted to know about a mounted propane tank.
https://rvlifestyle.com/innards-rv-propane-tank/
Also noteworthy is that you have MBS. Folks need to know that. I suggest you put it in your profile for future reference. My SS has a gas port on the door side in its very own compartment to connect grills and such. It is after the regulator so a direct connection can be used.
You can connect to your tank as BehindBars stated but that is before the regulator so your device would have to have one in line. Clearly installing a 4 way T (extend a stay) would be your best bet if you do not have a factory installed quick connect.
