Sometimes circuits check okay with a multimeter but don't work. Bad connections can pass the tiny amount of current from a multimeter but can't pass normal current. The most likely culprit since all are affected is a ground. Test by running a wire from a trailer light to the tow vehicle battery ground post. If the lights work with a good ground, leave it connected to the tow vehicle battery and move the other end until you find the bad ground.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
