02-28-2018, 08:19 PM
Valve stem extensions
Where can I get metal valve stems extensions for my outside duals?
02-28-2018, 08:20 PM
Should add the two tire places in my town do not have them.
02-28-2018, 09:01 PM
Amazon
02-28-2018, 09:22 PM
Director, FROG
If there's a truck stop in your area, they're likely to carry them.
02-28-2018, 09:24 PM
Found them at NAPA store. Even braided for the inner dual to come out thru the outer so I could hookup the tpms.
I think the outer are 130 deg metal extensions.
The new inner braided came with heavy clamps but I took those off and used the rest with the spring steel to hold in the wheel simulator.
Local CW had some also.
2014 3051S - First RV for us
2022 DX3 RB on order
02-28-2018, 09:49 PM
This company has a lot of tire supplies. BORG Equipment & Supply Corp. Inc. - Automotive Equipment & Supplies
I have gotten a few extensions from them.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
03-01-2018, 01:31 AM
Sunseeker 2400MBW
Originally Posted by Sagecoachdriver
We bought ours from Borg. Very helpful. We took it all to Les Schwab and they said they wouldn't install equipment they didn't sell. Then they decided they were out of what we needed and what we brought in was all correct. So they installed them after all.
03-01-2018, 04:40 AM
Senior Veteran RV Owner
Best mod I ever made was to get tire valve extensions installed. I got mine at the RV dealer. Makes the inner rear tires accessible to check tire pressure, and then use the TPMS sensors. Makes life so much easier!
Art Mullis
03-01-2018, 06:46 AM
Just my opinion, but I would recommend you look at the solid valve extenders as opposed to the braided lines. They come in various lengths and shapes. Much less prone to leaking. Ask me, as I had one fail on my rear outside tire on the dually on the way down to Florida this year. Replaced both sides with solid extenders purchased at a local tire shop.
Rusty
03-01-2018, 09:42 AM
For solid metal valve stems, Borg has them
Duallyvalve Kits for Ford, GM, Dodge - Class C
Also, Tireman in Ridgecrest CA. check for website.
03-03-2018, 04:37 PM
Found mine on Amazon good quality no leaks on one year.
03-03-2018, 05:00 PM
Kanadian Kamper
Solid over braided........every time.
Ken and Terry
2018 Sunseeker 2430S-CD carried by a 2017 Ford E450
Former Georgetown 330TS owner for 10 years with more mods than I can count.
03-03-2018, 10:09 PM
Thanks for the response, got some solid metal ones. Why do I need multiple valve cores in line. One in tire and 2 in extension. Plus I have gator caps which is another one. It took me forever to air up my tire. I remove the extensions and applied air through the extension and had little air flow coming out, is this normal?
03-05-2018, 12:06 PM
Our's are solid core,all metal and the inner valve ext. is bolted from the inside. NO LEAKS !
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
03-06-2018, 12:33 PM
Ditto for solid valves. Mine are Duallyvalves and they will literally maintain the psi for almost a year.
Steve
2016 3010DS Sunseeker
03-06-2018, 04:01 PM
Senior Members
Braided caused me nothing but leaks. So I converted to solid.
2015 3010DS Sunseeker
2010 Jeep Wrangler Unlimited
03-09-2018, 09:33 PM
What ever you decide, go by the parts house and purchase an inexpensive valve stem replacement kit. Take the little tool and snug up all valve stem cores. Handy tool to keep around. If you decide to use braided extensions, check the core as well. If you are not using a TPMS system, make sure to get quality valve stem caps, metal with integral gasket.
[ATTACH][ATTACH]
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
03-10-2018, 12:54 AM
Sunseeker 2400MBW
What is a *solid core tire valve*? How would you get air in your tire? I think I am misunderstanding something.
used to be - Full time 2016 Sunseeker 2400WS towing a 2018 Subaru Forester. 2021 we bought a house.....Still have the precious Sunseeker and tow car.
03-10-2018, 11:04 PM
I think that solid refers to the style of extender. Solid is referring to long hard pipes that are just long valve stems bent on such a way as to give the ability to add air to the tires easier. Some folks prefer these and some prefer the soft, flexible steel braided ones.
Does this help?
03-11-2018, 02:51 PM
Sunseeker 2400MBW
Hard metal pipes are what we installed, to replace the rubbery valves. THANKS for explaining. I kept seeing “solid core” over and over and got nosy.
