To find the height of your unit you need a ladder tall enough for you to see the roof from, a 2x4 about 8’ long that is fairly straight, a level and a 12’ or longer tape measure.
Place the 2x4 on the highest point (usually the Air Conditioner near the rear of the cover (the back of your unit is higher than the front so if you have a ladder it may be higher). Place or tape the level on the 2x4 2” side. With the bubble centered, measure the distance from the ground to the bottom of the 2x4 to get your actual height. Note: I use the measurement to the top of the 2x4 as my absolute minimal clearance.
Mike Dropped
