I recently saw a thread about their gray flooring was turning pink
I thought it was on the Forester Forum but I can't find any where, anyone see the "Pink" post
Thanks,
I had the "pink" plague on two vertical strips and assumed it was from a different adhesive used after the main floor was installed during build.
I asked a local rv dealer to order a 6x8 sheet of the same vinyl to recover the floor under the theater seating that I removed and replaced with pedestal recliners, I had to make the slide floor 10 inches wider and had a couple pieces left over to cover the pink areas. My only worry now is the adhesive I used might have the same reaction. I've got my fingers crossed.
