Old 05-24-2016, 08:10 PM   #41
Washing an RV is a lot like work...
Sorry I'm late replying to this post, but my nephew told me about this Protect All - All Purpose cleaner/wax and it's amazing. Don't bother scrubbing, just wash and dry. Once that's done, just use this Protect All.....it's amazing, takes off left over dirt, bugs black streaks no problem.
The only thing, it's mostly available in the states, but I have found some RV dealers here in Canada.
Joe O is offline   Reply With Quote
Old 05-25-2016, 07:17 AM   #42
Wolverine 1945's Avatar
Saw it yesterday @ Walmart !!!
Wolverine 1945 is offline   Reply With Quote
Old 04-20-2018, 04:58 PM   #43
Used this old thread to provide input I read on other numerous threads about washing and waxing the RV. I used Dawn soap to get rid of several weeks of Interstate grime and dirt and that worked well. Tried Scrubbing Bubbles to remove the old black streaks and that worked just fair. I used NuFinish as a wax coat and with a little (well maybe a lot) of elbow grease, the black streaks just disappeared. Could only do a couple of hours at a time as I ran out of elbow grease after that. It rained after my wax job and the start of new black streaks wiped off easily. Thanks to all the posts to help me out.
Scott V.
Far Northern, CA
Salem T25SL
GMC Sierra 2500
Scott V. is offline   Reply With Quote
Old 04-20-2018, 07:32 PM   #44
I use the Worx Power Washer on my rig. It is a power washer, NOT a pressure washer. It is rated at 850 psi and is completely portable. It works off a rechargeable 20v battery. Go to their website and watch the video. I do not work for them or receive any financial gain from them. It is just a great product.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 04-20-2018, 07:56 PM   #45
Cabinfever97's Avatar
We use BioKleen Black Streak Remover. I use the brush method, as described in their video. Works great and as fast as I would think anything else is. Then we wax with Lucas Slick Mist. Great wax applies easy.
2019 Hemisphere 272RL
2015 Ford F250 6.2L
Hensley Hitch
Cabinfever97 is offline   Reply With Quote
Old 04-22-2018, 02:59 PM   #46
Hoglou's Avatar
X3 on Protect All. Used in aviation for years.. A little goes along way, but tends to leave a haze for those with full body paint.. its ok on paint, rubber and glass.
If you use it on your roof you just created a skating rink...
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 04-22-2018, 03:28 PM   #47
Simple Green is great to strip wax/degrease, I use it first. Follow up with Blackfire Paint Sealant. Easy to apply and longest lasting I have found. The less you wash the longer it lasts and use a wash liquid that won't remove polish. Blackfire also makes a one step cleaner/polish Total Polish and Seal and One Step. These are expensive but great products. I've tried most out there like NuFinish, Meguiars, etc. and found these to be the best.
https://www.detailedimage.com/Sealan...Blackfire-M32/
Brewhedd is offline   Reply With Quote
