Old 08-06-2017, 08:55 AM   #1
hockeytownmom's Avatar
Water damage in front of fridge 3170
I just discovered the floor in front of the fridge is soft. Anyone else run into this with this model? I pulled off the fridge vent, it's draining to the outside properly. I pulled off the furnace vent and no signs of water there either.
hockeytownmom is offline   Reply With Quote
Old 08-09-2017, 06:47 AM   #2
geezer with gadgets
757Dave's Avatar
Have you had a chance to pull the cover on the outside/backside of the fridge to see if there is any water damage to the wood flooring in that location?
Also, I would pour about a cup of water in the tray under the metal fins in the fridge and see if the water is actually draining out of the camper or going some place else.
We have a "soft spot" between the couch and the dinette. No water anywhere nearby. Go figure!
Good luck and hope its nothing major for you to worry about.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
757Dave is offline   Reply With Quote
Old 08-10-2017, 03:43 PM   #3
moxnix92's Avatar
Does your fridge have an ice maker? That was the problem for me. I took it out and no more wet floor.
Steve
2016 3010DS Sunseeker
moxnix92 is offline   Reply With Quote
Old 10-22-2017, 07:53 PM   #4
Everything is dry under the fridge, no ice maker. I really think it's from the slide.
Kristina
3170, fridge, water
