Old 05-03-2013, 08:22 AM   #1
Water filter
The dealer didn't install the water filter in the plastic bin so I don't have a model to follow. Does it just rest in the plastic bin? Or do I need to do anything special (install a certain way, screw in, etc)? Thanks!
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 05-03-2013, 08:26 AM   #2
Wat too much Info & the Pix isn't very clear! Youroo!!
Old 05-03-2013, 08:27 AM   #3
Huh?
Old 05-03-2013, 08:28 AM   #4
Unscrew the clear canister, place filter element inside,screw back on. Youroo!!
Old 05-03-2013, 12:32 PM   #5
Just make sure the rubber gasket is seated well. Then check for leaks.
2020 Flagstaff Micro Lite 22FBS
Old 05-06-2013, 06:39 PM   #6
Smile
I installed my filter on our Sunseeker 2860 this last weekend on our maiden voyage. Suggest if you have a drain hole on the floor you unsrew it first. The empty canister is filled to the brime and you will spill a little when you tip the canister to remove it. As yes watch out for the black rubber seal. When I opened the filter it popped out on the ground. Otherwise straight forward and no leaks. The canister wrench worked great.
Wildkats66 is offline   Reply With Quote
Old 05-06-2013, 08:17 PM   #7
Place a coffee can under the canister to collect spillage.
l001952119 is offline   Reply With Quote
Old 05-06-2013, 08:23 PM   #8
TURBS's Avatar
Lol can you even get a coffee "can" anymore?
Old 05-07-2013, 01:34 AM   #9
sail2liv's Avatar
I prefer external filter over one inside.....still have the one that came with trailer as never installed it....just got one of the filters that you can screw on the spigot before the water enters the hose....attach pressure regulator there too and keeps filtered water running thru dedicated water hose for camper....good luck....
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
