Old 05-08-2017, 08:37 PM   #21
KayleysMom's Avatar
Originally Posted by Wandering View Post
Thanks for share. EB Tape going on mine this weekend.
Ours also!
2017 Forester 2861DS
Chevy Chassis
KayleysMom is offline   Reply With Quote
Old 05-08-2017, 08:58 PM   #22
crunchman12001's Avatar
Originally Posted by Snowman9000 View Post
Rusty water has been leaking out of the front end of the same trim on the other side. That would have been happening while the MH was parked nose down during the rain.
So something steel inside the cab structure is getting wet. Could be the trim screws. Or maybe there are steel studs in the walls? If it is those, that indicates marker light, window, or roof leaks, huh?
I will be getting some vinyl trim insert in the next couple of days. I'll see what I can see when I remove the old piece.
I am going to order a "pinless" moisture meter on Amazon, or get it at Home Depot. It can check to a depth of 3/4", without making a penetration at all. This would be to use on the inside walls etc., to get an idea what might be in there.
The rusty water will most likely be coming from the screws themselves, indicating the butyl tape failed. Buy a box of new screws. Remove 1 screw at a time, fill hole with sealant and replace with a new screw if the old one is rusty.
2015 F-250 FX4
Old 05-09-2017, 07:32 AM   #23
Yeah, but that is plugging the bottom end of the drain path.
In my way of looking at it, stopping the water from getting in above the screws is the issue.
2014 Sunseeker 2300 Chevy
Snowman9000 is offline   Reply With Quote
Old 05-09-2017, 07:40 AM   #24
SidecarFlip, you might be right about the 60 MPH driving. Or maybe that's a fairly dead air zone on the roof. I would not be surprised.
I think the real issue is the water that is dammed up in the four corners. Last evening we had a tiny rain, literallyjust a few sprinkles. I went up on the roof to plan the repair. Each corner was holding water. Maybe it is only 4 ounces per corner, give or take. But if and when the seam fails like mine did, every tiny sprinkle will funnel 4 ounces of water into the RV.
I did a Dicor repair last night. EB Tape will be as soon as I can get to it, since we are on the road for a few weeks now.
water
