Old 10-26-2018, 06:46 AM   #1
water in taillights
Hi all I have a 2016 3010 Sunseeker class c motorhome. Have a problem with water getting into rear tail lights. How should I rectify this for future. Cannot keep paying service guys to fix things. Senior lady needs help!! I'm in southern Ontario Canada.
Mstoad is offline   Reply With Quote
Old 10-26-2018, 12:24 PM   #2
Msttoad, is the water sitting inside the red lens or is the water getting BEHIND the lights and into the camper wall? A picture if possible would help. Jay
Jay2504 is offline   Reply With Quote
Old 10-26-2018, 01:47 PM   #3
If inside the lens drill two drain holes on the bottom. Use clear silicone lightly on 3 sides of the lens. leave the bottom open.
If behind the lights ( I would look anyway) seal the holes were the wires go in
Old 10-26-2018, 07:37 PM   #4
I have the same problem on my 2016 3010DS. The suggested solutions confuse me because these are LED taillights. The condensation is on the inside of the lens wich is also the component board surface for the LED's. In Vermont this will not pass inspection. They replaced it and a month later the new one looks just like the old with condensation in there. Can you provide more clarification on the suggested fix please.
kins83 is offline   Reply With Quote
Old 10-26-2018, 08:17 PM   #5
drill a drail whole in the bottom of the lense.
Old 10-27-2018, 03:00 PM   #6
Hi we did drill a small hole and hopefully have resolved the problem
Old 10-28-2018, 07:47 AM   #7
geeman53's Avatar
We have a full width slot at the bottom of the lights that stops condenstation .
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
Old 10-28-2018, 07:59 AM   #8
KyDan's Avatar
A close up photo would be very helpful.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-35
Old 10-28-2018, 12:20 PM   #9
Our original lights had two screws attaching the backup light lens to the red portion of the light. Because they were leaking, we had the lights replaced with an updated version when we were at the 2016 FROG Rally. The updated ones have four screws attaching the backup light lens.
The leaking stopped for a while with the new lights, but we did have one additional problem. While attempting to tighten things down due to a new leak, I discovered that one of the upper mounting screws for the left light had a stripped out mounting hole. I glued some pieces of toothpick into the hole and remounted the light. Now they stay dry inside and have been so for nearly two years.
The lights have to be very tightly mounted to avoid leaks. Just be careful not to tighten to the point of cracking them.
2016 Sunseeker 2300C
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts." - Bertrand Russell
SS Cruiser is offline   Reply With Quote
Old 10-28-2018, 03:28 PM   #10
KyDan's Avatar
IF tightening them keeps out the moisture then the answer is easy.
Remove the lens.
Dry thoroughly!!!!
Apply a tiny bead of your favorite flexible
white caulk to the edge of the lens.
Go around each screw and put a tiny dab under the screw heads.
Re-attach lens.
I had to do the above to my previous Rockwood on all the clearance lights.
They all leaked.
Some leaked inside!!
The tiny bead of caulk stopped all the leaks and you can't see it because even tho the lens is amber or red the side of the rig is white so the caulk doesn't show.
Go camping!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 11-02-2018, 01:36 PM   #11
Hoglou's Avatar
weep
X3 on a small wep hole.
Hoglou the DH (01.01.21 done and retired)
BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
