Not trying to pass off giving advice but water leaks are one of those things that is awfully hard to give good advice about when we are not there in person to see what is happening.
Water can (and does) wick from places far away from where it shows up.
Couple that with the possibility of a slight plumbing leak and all bets are off.
If it is new, you need to return to your dealer or find someone reputable that can locate and repair the leak for you.
Not what you wanted to hear I'm sure but I'm simply pointing out the fact that on this issue, you could get 6 pages of suggestions and not one of them be helpful for your particular condition.
BTW... second post... WELCOME!
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 ☼ '18=49 ☼ '19=58 ☼ '20=110 ☼ '21=116 ☼ '22=88
